Could not connect scene graph socket problem
Old   August 15, 2015, 18:05
Default Could not connect scene graph socket problem
tjanosik is on a distinguished road
i have a problem, while starting or loading a simulation this warning appears:
could not connect scene graph socket to MyPC:47827 from 192.168.1.12
I ve already installed this ccm to other two laptops and it worked perfectely.
I just bought a new laptop and this happened. Its running on Windows 8.1
Please,can anyone help?
tjanosik is offline   Reply With Quote
Old   November 4, 2015, 17:23
Default Could not connect to scene graph socket
Sero93 is on a distinguished road
Hey tjanosik,
i've got the same problem and cant figure out how to fix it.
Did you find a solution?
Best regards
Sero93 is offline   Reply With Quote
Old   August 10, 2016, 10:14
Hey,
yes it worked for me but now after reinstaling windows same problem appeared.
Have you solved yours?
Old   August 12, 2016, 05:33
Hey,
yes i have fixed the Problem, it was my connection to the Internet, i am not sure why, but it appears that i cant use the Programm with my LAN cable plugged in. When i used my Wifi the Programm just worked fine.
I hope this may help you.
Old   November 19, 2016, 09:36
André van der Walt
DEM_Andre is on a distinguished road
Hey guys, any luck on further fixing the problem? My newly installed StarCCM+ does not want to work, because of this problem. I am running Windows 10 and StarCCM+ 11 with a POD licence. I have changed my internet connection 3 times already, all on WiFi.
Kind regards
DEM_Andre is offline   Reply With Quote
Old   February 16, 2017, 15:54
Jørgen Tønne
Jorgen1 is on a distinguished road
Hey.have you found a way to solve the problem?
Jørgen
Jorgen1 is offline   Reply With Quote
Old   February 17, 2017, 01:08
Default Graph Scene socket issue
André van der Walt
Hey Jørgen,
I have fixed my problem, it seems like it was some antivirus program that was pre-installed on my laptop that caused the isssue where the antivirus blocked Star-CCM+ to comunicate through the firewall. The unfortunate thing is that once the program starts to show these symptoms it makes a restore point in the installation somewhere and I couldn't find that.
The solution I had to do is reset my laptop (basically format and reload Windows), in some cases UNINSTALL said antivirus before installing Star-CCM+ and then only will the issue be resolved.
Regards
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
