Deleting boundaries without getting "free edges"
Old   October 19, 2015, 11:11
Default Deleting boundaries without getting "free edges"
Justin
jpesich is on a distinguished road
Hey all!
I have a very complex car geometry and would like to delete some of the unnecessary boundaries in the engine compartment. When I delete these boundaries in the parts tree, my wrap has fairly good surface quality (no free edges) but some face quality issues. But when I assign parts to regions and do region based meshing, my surface mesh has thousands of free edges from the holes left from the deleted boundaries.
Is there any way to get around this? Thanks!
jpesich is offline   Reply With Quote
Old   October 19, 2015, 13:28
me3840 is on a distinguished road
Boundaries are in regions, not in parts. Do you mean you're deleting part surfaces?
This implies you're using a parts-based wrap but a region-based mesh? Why? I would do everything in parts.
If your wrap has no topology issues then the output of the surface remesher shouldn't have any either; are you sure you assigned the output of the wrap to the region and not the original parts?
me3840 is offline   Reply With Quote
Old   October 19, 2015, 13:32
Justin
me3840,
Yes, I mean I am deleting parts.
I do this because of how the simulation assistant I use is setup. I eventually will change but it really doesn't matter.
I think after I wrapped, I didn't re-assign parts to regions. I need to re-assign my parts (wrapper) to regions and then mesh.
No flow through periodic (cyclic) boundaries in impeller with foam-extend-3.1 anttiad9000 OpenFOAM Running, Solving & CFD 3 March 2, 2016 19:37
2D Rotating Detonation Engine Periodic Boundaries whitet86 FLUENT 2 June 25, 2015 11:04
Setting Flow/Pressure Boundaries in Floworks Eran FloEFD, FloWorks & FloTHERM 3 August 11, 2009 04:23
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 11:58
mass flux correction at outflow boundaries Subhra Datta Main CFD Forum 2 November 24, 2003 13:11
