change dimensions on an existing mesh
Old   October 14, 2015, 19:04
Default change dimensions on an existing mesh
abcdesi is on a distinguished road
Absolute newbie to STAR-CCM+
I have a mesh that I've imported into STAR-CCM+. For starters, how do I (see existing dim) and change the dimensions? Help much appreciated
abcdesi is offline   Reply With Quote
Old   October 14, 2015, 19:28
me3840 is on a distinguished road
What kind of mesh did you import?
I'm not sure what you mean by see existing dimensions. You can plot a scalar field of position in any direction on your model by simply adding your surface to a scalar scene and picking position as the function.
me3840 is offline   Reply With Quote
Old   October 15, 2015, 00:08
Thanks me3840. I'll try that tomorrow since I don't have access now. The mesh file has an extension .ccm and is just a very simple structured (rectangular) mesh. But any ideas on how to change the dimensions? By that I mean let's say the original dimensions of the meshed surface is 2m x 1m. Would I be able to change it to say 3m x 0.5m? If so, how?
Old   October 15, 2015, 16:00
You can transform a region by right-clicking it and saying transform > scale
Old   October 15, 2015, 17:09
1. In the mesh that I have loaded, I would like to know the dimensions so that I can use the transform->scale option to make the part/region have the dimensions that I want
2. Using the mesh that I have loaded, I'd like to change the resolution while retaining the same boundary names, etc...
I'm having a hard time doing either of these. I'm now wondering if these can be done at all?
Thanks
Old   October 15, 2015, 17:29
1. If you want to know the dimensions of the region, just make minimum and maximum reports for position in x, y, and z. That will tell you the bounding box of the mesh.
2. I'm not sure what you mean by change resolution. Do you mean you want to remesh it? If so you need to extract the boundary surfaces, import that surface as a part, and mesh it like normal. But the sizes of the initial surface will be retained, so you cannot get a finer boundary surface than you already have.
Old   October 15, 2015, 18:02
Thanks me3840. That is exactly what I want to do: rescale and remesh. Was able to rescale following what you said. After that I selected File-> Export and chose the boundaries and saved it in .ccm format. Then I imported it, but seem to have not gotten anything back So, can you please elaborate on the export and remesh procedure. Sorry, as I mentioned I'm a total newbie...
Old   October 15, 2015, 20:26
If you already have a volume mesh imported, this is the procedure to extract a surface of the mesh:
Go to the bottom of the tree and find representations>volume mesh>right click> extract boundary surface
That will make an extracted surface representation. You can right-click that and export it as a .dbs file. Import that and mesh as normal.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
Radiation interface hinca CFX 15 January 26, 2014 17:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
