October 19, 2015, 06:11 |
"No FvBoundary found"
Rep Power: 11 |
Hi folks,
While trying to run a simulation on one of my models I got the following error: "No FvBoundary found for boundary: Outlet_V" What does this mean? How can I fix it? Thanks! Jambond |
October 19, 2015, 11:54 |
Rep Power: 24 |
It means you have a part surface which is not assigned to a boundary or its mesh has become corrupted. Check that that part surface exists, has faces, and is assigned to a boundary.
October 20, 2015, 09:41 |
Rep Power: 11 |
Thanks for your reply
Compilation Error: "no matching function for call to ‘div(Foam::volScalarField&)’" | abhiv | OpenFOAM Programming & Development | 1 | September 30, 2015 03:47 |
[Gmsh] OpenFoam Error Message: "no cells read from file .msh" | kayla1994 | OpenFOAM Meshing & Mesh Conversion | 1 | July 13, 2015 10:26 |
Problems using a qsub (PBS) job-scheduler: "no access to tty (Bad file descriptor)" | heliana60 | OpenFOAM Running, Solving & CFD | 4 | January 28, 2015 08:14 |
Error:"Unable to attach geometry", "no valie bodies" | TheForumLord | ANSYS | 0 | July 1, 2014 07:21 |
CAVITATION "no CONVERGENCE in non-cavitating flow" | ROOZBEH | FLUENT | 9 | December 1, 2003 03:51 |
