Working with multiple interfaces
Old   December 26, 2015, 10:27
Default Working with multiple interfaces
Jacopo
JacoGab is on a distinguished road
Hi everybody,
I'm an italian engineer who works with STAR-CCM+ and I wonder if someone found (and somehow resolved) my same problem.
I have three regions that have to interface between themselves. In particular, I have two static regions and a moving one, and the moving region interfaces one of the static regions with the overset mesh interface. Then, I need to put an internal interface between the other static region and the two regions coupled with the overset mesh, but this would involve an interface with three surfaces and from what I have understood STAR creates interfaces only between two surfaces per time.
Has anybody dealt with this problem?
I thank you all in advantage for your attention!
JacoGab is offline   Reply With Quote
Old   January 4, 2016, 14:55
Matt
fluid23 is on a distinguished road
could you post an image explaining this? it is hard to visualize how you would ever need an interface that has 3 surfaces.
fluid23 is offline   Reply With Quote
Old   January 7, 2016, 05:38
Jacopo
Hi MBdonCFD,
I hope that this image could explain what is the problem. The interface should be set between the three surfaces represented by the star, the surface that should be coupled twice is the one that belongs to region 1.
By now, thanks for your attention!!
Old   January 7, 2016, 09:11
Matt
Ah, I see... Could you extend Region 2 (static) so that it totally encapsulates Region 3 (moving). That way the overset mesh interface will be Region 2 <---> Region 3 and the internal interface would be Region 1 <---> Region 2?
Old   January 7, 2016, 11:19
Jacopo
Unfortunately, this isn't possible, as for coupling reasons between region 2 and 3 i have to keep this configuration.
Old   January 7, 2016, 11:29
Matt
I would log a case on the steve portal and get a support engineer to assist. I am not sure what to tell you beyond that.
Old   January 7, 2016, 11:32
Matt
Actually, I'm not sure if this would work but you could try splitting the interface on region 1 into 2 faces so each has a separate surface for the interface, an inner circle and outer ring (just like what is seen on region 2/region 3 common plane).
Old   January 8, 2016, 04:15
Jacopo
Neither that would work, I've already tried. Maybe I should ask for a support engineer as you suggested!
Discontinuity across interfaces Nurzhan CFX 2 March 11, 2015 01:59
UDF is working in Laptop, but not working in Serial Cluster Tanjina Fluent UDF and Scheme Programming 0 December 20, 2013 21:42
Mesh interfaces and reactions in porous media - why not working? RossFS FLUENT 0 December 15, 2013 05:40
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
What type is defined as the interfaces between stator and stator on OF-2.1.1? renyun0511 OpenFOAM Running, Solving & CFD 3 May 18, 2013 08:11
