April 19, 2016, 09:09 |
Heat transfer modelling
wang hongchao
Rep Power: 10 |
I am now running a vehicle thermal simulation, and use the singel stream model to simulate the heat transfer, during calculating, there always arise the notice-Heat transfer temperature limited in the output window, who knows how to solve this problem, thank you!
April 24, 2016, 19:13 |
Rep Power: 24 |
If you are getting temperature limitations it's likely your simulation is diverging. Check your mesh and boundary conditions. Often it's prudent to run heat exchanger models for a few hundred iterations without heat to let the flow converge first.
April 24, 2016, 21:43 |
wang hongchao
Rep Power: 10 |
From the residuals, it seems that the calculation didn't diverge, Maybe the mesh quality is the main problem, and I will take your advice to run another simulation to see the results, thanks for your reply!
temperature limit |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 04:07 |
Modelling Heat transfer between stack and gas in Thermoacoustic | Chirag2302 | FLUENT | 0 | April 24, 2012 01:14 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Modelling combustion and heat transfer | Tudor | FLUENT | 4 | May 9, 2005 07:02 |
