April 17, 2016, 06:57 |
How to "cut" a surface inside another one?
Fulvio
Rep Power: 10 |
I've been trying to do a 2d sim. Let's assume I want to model a big square, inside which I want to put another smaller square that acts as a heat generator. If I make the sketch of a square inside a square and I extrude it, I will have a square region with a square hole in the middle. Is there a way to have the whole square surface with another square surface inside? If I do it by making two different sketches, the software automatically merges them. Any help? I don't think I have access to any other cad software, so the import/export trick is quite difficult. If you can suggest other modelling ideas, I will hear them. All the best |
April 24, 2016, 19:09 |
Rep Power: 24 |
On your extrudes, set the body interaction property to none. Then do a boolean subtract of your geometries.
April 27, 2016, 03:50 |
#3 | |
Fulvio
Rep Power: 10 |
Btw I think there's no need to do the boolean subtraction if the two sketches are very close (i.e. under the minimum tolerance for creating an interface). |
Calculating forces on a non-closed surface | ScottN | FLUENT | 0 | March 1, 2011 17:18 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
free surface inside a stirred tank | mystic_cfd | FLUENT | 5 | December 11, 2002 09:27 |
How to determine a point is inside a tetrahedral? | G.P. Xia | Main CFD Forum | 16 | January 12, 2000 11:15 |
