Interface between two directed meshes
Like Tree1Likes
  • 1 Post By marmot
Old   May 5, 2016, 12:09
Default Interface between two directed meshes
Christoph Hachmann
Chris_2002 is on a distinguished road
I am simulating a rotor applying a momentum sink to a flow. I've used the Directed Mesh option for the rotor disk and trimmed cells for the fluid. I included a buffer zone, also with a directed mesh, between the rotor and the fluid in an attempt to improve the solution near the boundary between a region with momentum sink term and the rest of the domain without momentum sink term, see image 1.
However, when doing so I get spots along the interface where the streamwise velocity is virtually 0, see second image. Where does this come from and how can I get rid of it?
I've looked into the interpolation between Parts Meshes but a change to higher-order stencils didn't change the result.
It'd be great to hear from anyone who might have a solution to this.
Thanks!
Chris_2002 is offline   Reply With Quote
Old   May 9, 2016, 10:07
kevin alun
marmot is on a distinguished road
This could be due to the interface not being 100% matched, you can increase the tolerance when creating the interface to improve matching.
When you create an interface you have a parent and child boundary, switch the parent boundary to symmetry than the unmatched surfaces will have a velocity, could be they are wall now.
Chris_2002 likes this.
marmot is offline   Reply With Quote
Old   May 9, 2016, 10:35
Christoph Hachmann
I also got in contact with CD-adapco and it turns out that there was a problem with the interpolation. However, this was not on the simulation/meshing side but rather on the plotting side. I chose the "smooth filled" option for the contour plot which uses an interpolation to smooth the contours. This interpolation can cause spurious effects. When I changed it to "filled" it looked perfectly normal and as expected.
So I think it's safe to say solution found.
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 08:16
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Interface w. Pitch Change: Thcfd CFX 0 December 22, 2010 03:50
meshes interface ? amine CFX 1 March 7, 2008 13:42
