Macro for parametric study in STAR CCM+
Like Tree2Likes
  • 2 Post By marmot
Old   July 1, 2016, 18:40
Default Macro for parametric study in STAR CCM+
cfdblender is on a distinguished road
I need to do a parametric study in STAR CCM+. The study will have anything between 50 and 150 runs. In each run, several parameters of the CAD model geometry will change, then the new model is remeshed, simulation run.
Obviously, doing this by hand would be very inefficient.
I'd like to use a macro that will read the parameters for each run from an Excel (or .csv) file, then remesh, run simulation and perhaps even save some key numerical results to another spreadsheet.
Does anyone have macro that does something similar to this?
Thanks in advance!
cfdblender is offline   Reply With Quote
Old   July 4, 2016, 08:40
kevin alun
marmot is on a distinguished road
People make a living off of that, but really just record yourself changing the design parameters, once that is changed its just one command to mesh and one command to run, writing out results, below are some basic java commands that are helpful for writing out data from a simulation,
Simulation sim = getActiveSimulation();
String filePath = sim.getSessionDir().toString();
String simName = sim.getPresentationName();
ArrayList<Double> someValue = new ArrayList<Double>();
ArrayList caseNameList = new ArrayList(); (define a list of case names probably related to your design changes or read from csv file)
For loop
//Changing design parameters,
mesh
run
get a value
aValue = avgReport.getValue(); (assuming you created an AvgReport variable)
someValue.add(aValue);
end the loop
FileWriter fstream;
BufferedWriter reportfile = null;
try{
fstream = new FileWriter(filePath + File.separator+simName+caseName+"SomeValue"+".csv" );
reportfile = new BufferedWriter(fstream);
reportfile.write(caseName+","+"ValueType");
reportfile.write("\r\n");
for loop
reportfile.write(caseNameList.get(i).toString() + "," + someValue.get(i).toString());
end loop
reportfile.close();
}catch {something here}
cfdblender and bikooo3878 like this.
marmot is offline   Reply With Quote
Old   July 5, 2016, 13:08
Thank you, marmot! That is brilliant!
macro, parametric study, star ccm+
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 22:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
error in star ccm maurizio Siemens 3 October 16, 2007 05:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
