Re JAVA MACROS
Like Tree1Likes
  • 1 Post By kamal tewari
Old   August 10, 2016, 14:05
Default Re JAVA MACROS
Polard
kamal tewari is on a distinguished road
Hi all
I am designing a adaptive controller which takes input from 2 reports(at two points in flow) and then apply the FIR algorithm in order to get minimum error to adapt for system changes. For this I need to write a java macro . I have written a macro for this as shown below but it is showing the message Run Time Error Plz help.
package macro;
import java.util.*;
import star.common.*;
import star.base.neo.*;
import star.base.report.*;
import star.common.ImplicitUnsteadySolver;
import star.common.PhysicalTimeStoppingCriterion;
public class Testing extends StarMacro {
public void execute() {
execute0();
private void execute0() {
Simulation simulation_0 =
getActiveSimulation();
MaxReport maxReport_1 =
((MaxReport) simulation_0.getReportManager().getReport("Maximum 3")); // Reads data of error microphone to file
MaxReport maxReport_2 =
((MaxReport) simulation_0.getReportManager().getReport("Maximum 1"));
PhysicalTimeStoppingCriterion maxTimeStoppingCriterion = (PhysicalTimeStoppingCriterion) simulation_0.getSolverStoppingCriterionManager().g etSolverStoppingCriterion("Maximum Physical Time");
maxTimeStoppingCriterion.getMaximumTime().setValue (80.0); // Change maximum physical time here
double X[]={0,0,0,0,0,0,0,0,0,0};
double err=0;
double mu=0.01;
double w[]={0,0,0,0,0,0,0,0,0,0};
double d[]={0,0,0,0,0,0,0,0,0,0};
double timeStep = ((ImplicitUnsteadySolver) simulation_0.getSolverManager().getSolver(Implicit UnsteadySolver.class)).getTimeStep().getValue();
do {
if (simulation_0.getSolution().getPhysicalTime() > 0) // Change Solution time after which macro is to be executed
X=d;
double currentNoise=maxReport_1.getReportMonitorValue();
double inputNoise=maxReport_2.getReportMonitorValue();
d[1]=inputNoise;
double op1=currentNoise;
double op2=0;
for (int j=1;j<11;j++)
op2 = op2 + w[j]*d[j];
err=op1-op2;
w[j] = w[j] + 2.0*mu*err*X[j];
for(int j=10;j>1;j--)
d[j] = d[j-1];
simulation_0.getSimulationIterator().step(1);
} while (!maxTimeStoppingCriterion.getIsSatisfied());
ramakant likes this.
kamal tewari is offline   Reply With Quote
Old   August 11, 2016, 09:59
Schwob77 is on a distinguished road
Can you please post the error message that you get.
Did you make sure, that all reports have the correct input parts to deliver reasonable values? Do the reports have the correct Representation applied?
Schwob77 is offline   Reply With Quote
Run Java macros in Star Ccm+ peter parkour STAR-CCM+ 2 November 6, 2015 02:48
Macro to access java files in sub-directory abraum STAR-CCM+ 3 July 11, 2012 02:46
Open simulation Java Macros nico Siemens 2 June 9, 2007 06:41
Getting OpenFOAM to coexist with an existing JAVA VM nik777 OpenFOAM Installation 5 February 22, 2007 07:21
What are UDF macros C_T_S , C_T_AP,...???? Asghari FLUENT 0 January 28, 2007 10:54
