Structured Meshing with a Radial Pattern in Star-CCM+ |
August 26, 2016, 16:51 |
A E
Rep Power: 10 |
I am trying to mesh a cylinder look domain by the structure mesher with a radial pattern like the picture attached. Any help is highly appreciated. I tried the directed mesh option but the mesher does not recognize the circles as the edges for the source surface. Best, A E |
August 29, 2016, 16:12 |
Matt
Rep Power: 17 |
Star-CCM doesn't really do structured mesh. Directed meshing is as close as you can get. If it isn't getting close enough for your liking, you will need to resort to a 3rd party meshing software and import the mesh.
August 29, 2016, 16:27 |
#3 | |
A E
Rep Power: 10 |
Best, Amir |
September 7, 2016, 00:47 |
Rep Power: 24 |
You can make that type of mesh if it is what I think it is - is the center hollow? i.e. no mesh there?
If you need a center, the directed mesher can do that, but you have to make a square block in the center of the circle, so your final mesh will not look like the one you posted. If you want a structured mesh you can't source it from any other mesher than the patch mesh. |
September 7, 2016, 16:50 |
A E
Rep Power: 10 |
Thank you very much for your reply. Yeah, I finally used a revolved rectangle to generate the directed mesh.
radial distribution, star ccm, structured grid |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
how to open star ccm 6.04 version file in older versions | pritam.edke | Siemens | 2 | June 25, 2012 03:14 |
Problem In Star CCM Plus | ramarya | STAR-CCM+ | 1 | July 10, 2011 05:59 |
structured and unstructured grids | user | Main CFD Forum | 6 | November 25, 2010 01:14 |
structured meshing | Mavinakere | FLUENT | 4 | March 1, 2002 15:52 |
