Integrating along a streamline
Like Tree1Likes
  • 1 Post By ping
Old   October 28, 2011, 09:27
Default Integrating along a streamline
Jeff
JPBodner is on a distinguished road
Damage to red blood cells in a flow is often evaluated by an equation like this:
damage=a*(shear stress)^b * (time)^c where a,b,c are constants.
Here, time is the time of exposure at the local value of shear stress. In other words, the idea is to integrate this along a streamline to determine how a particular red blood cell would be damaged.
Anyone know how to integrate an expression like this along a streamline in STAR-CCM+?
JB
JPBodner is offline   Reply With Quote
Old   October 29, 2011, 10:09
Robert
RobertB is on a distinguished road
Had you considered doing it as a source term. To find out flight time I think you put in a source term of density (it's in one of the examples). Thus you can see how long it takes to get from the inlet to a point.
You should be able to generate a source term which will essentially be the damage incurred while in that cell and the code will integrate it for you.
You can also see where the most damage is done purely by plotting up the source term (you may need to normalize by volume).
The other option is to run tracks, get the track file format from CD, dump the other data you need and write a program to do it externally.
RobertB is offline   Reply With Quote
Old   November 7, 2011, 05:57
Ping
ping is on a distinguished road
on a quick think about this, I dont think you need streamlines or the 'age of flow via density' technique mentioned by robertb as used to measure age of air in buildings. you say the damage is time at a certain shear stress, so it would seem to me that you just need a field function which works out the damage during the current timestep = shear stress * dtime (with your constants included of course). then you need to add this to the current sum of damage to get the new total damage locally everywhere in the field. do the sum using a field monitor of type sum. plot this scalar field function. seems simple to me?
ping is offline   Reply With Quote
Old   November 7, 2011, 07:49
Robert
This would only provide total damage in the domain. It is likely that to design better parts you will need to attribute local damage to specific features which I do not believe this technique will do.
Old   November 8, 2011, 03:14
Ping
...it is not the total sum (that is a simple sum report) but the sum in each cell - this is why field monitors are such wonderful tools. however on second thoughts this is not what you want - it would tell you where the worst cells for creating damage are in fluctuating flow.
Whereas you need the transported damage summed, so you should be using a passive scalar for this: create the field function for your damage variable; add a passive scalar; add a region source for this scalar and use the damage field function as the source for the scalar. to get the units correct your might need to think about it a bit. i did this in a little test and the results are in the image - you can see the local shear stress at the top and the passive scalar below, with high values in the recirculation zone behind as one would expect.
Old   November 8, 2011, 17:57
Thumbs up
Jeff
Yes, Ping. I think you have the idea that I came upon independently. (Actually, see "Fast three-dimensional numerical hemolysis approximation" by Garon and Farinas, Artificial organs, 2004.) Some people use the streamline approach, but the problem is that it only gives you an answer along the streamlines you happen to select. Also, in order to calculate the residence time, you need to use cell size and the velocity field, and this can be sketchy near the no-slip walls.
So, the preferred approach is to use a passive scalar and then use a source term to generate local damaged protein and then it can convect downstream to other parts of the flow. It's an Eulerian approach vs a Lagrangian approach.
Now the trick of the implementation is to come up with a representative shear stress (tau) for each finite volume cell. The paper suggests a von Mises type of approach. Does anyone know how to extract the stress tensor components in STAR-CCM+? They're not standard outputs.
Thanks for the input!
Originally Posted by ping View Post
Attachment 9910
Old   November 8, 2011, 18:05
Jeff
Now that I think about it, the only problem with the above approach is the conservation of red blood cells/proteins. You can generate an amount that exceeds what comes in potentially. I think I might also define another passive scalar representing the undamaged concentration and link the two such that the total damaged concentration cannot exceed the supply of undamaged entering the system.
Old   November 8, 2011, 18:44
Ping
glad it is looking feasible now. here is a shear stress field function i have used in the past (turn on 'temporary storage retained' in solver):
sqrt( mag2($$U_VelocityGrad) + mag2($$V_VelocityGrad) + mag2($$W_VelocityGrad) ) * $DynamicViscosity
bluebase likes this.
Old   October 14, 2016, 03:35
Smile
kastarkas
kastarkas is on a distinguished road
Greeetings to all,
Thanks a lot for this above discussion.
PLease excuse me to join this conservation here to seek some continuity of my previous thread
http://www.cfd-online.com/Forums/cfx...searching.html
I too work on the same problem for my thesis.
The eulerian approach has been discussed above. The alternate solution to find the exposure time and trajectory of each blood cell is via a Lagrangian Approach.
So for that I have doubt on "whether a variable with the value of an expression, can be integrated along the pathlines" using some functions in CFX ??
By doing Length Integral over the pathlines, will that be right ?
Can someone please explain how to implement it in CFX ?
It would be really blissful if someone can help me out.
kastarkas is offline   Reply With Quote
Old   October 15, 2016, 03:53
Ping
you had better convert to STAR-CCM+, or find a CFX forum
Old   October 15, 2016, 05:18
kastarkas
Witty one dear ping.
I never found anything in CFX forum.
But can you please confirm the logic ?
what does dense streamline mean sunflower FLUENT 0 June 8, 2011 01:48
streamline plot for multiphase problem lionlove0903 OpenFOAM Post-Processing 2 March 14, 2011 15:25
[OpenFOAM] points over streamline in paraView cedric_duprat ParaView 0 January 12, 2010 03:04
Streamline superimposed on velocity field allamarein FLUENT 0 July 9, 2009 20:51
Streamline diffusion Hong Main CFD Forum 0 May 18, 2000 08:10
