October 10, 2016, 17:58 |
Mesh cells growing too large
Brad Perfect
Rep Power: 12 |
I'm trying to run a simple Poiseuille flow simulation, and running into issues with the mesher. No matter what size I choose for the Base Size, I'm ending up with cells in the middle of the pipe that are ~10% of the pipe diameter. Is there some way I can tell STAR-CCM+ to not, under any circumstances, create a mesh cell with a dimension larger than a given value?
October 12, 2016, 17:21 |
Matt
Rep Power: 17 |
What mesher are you using?
October 12, 2016, 17:55 |
Brad Perfect
Rep Power: 12 |
It's a 2D application- I've tried triangles, rectangles, and polyhedral, all with similar results.
October 13, 2016, 09:27 |
Matt
Rep Power: 17 |
Well... for trimmed mesh (rectangle) you can specify maximum cell size.
for polyhedral mesh you can specify volume growth rate. Check out the help documentation under: User Guide > Meshers > Volume Meshers > Volume Mesh Control and Values |
October 24, 2016, 23:11 |
Chaotic Water
Rep Power: 17 |
Decrease "Surface Growth Rate" or try any other "... Growth Rate" in Mesher "Default Controls"
October 27, 2016, 20:52 |
check
RayJang
can u just check the global mesh size and specific region mesh size together
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
