November 27, 2016, 12:31 |
Turbulence suppression not converge
Salvatore Timpani
I community, sorry for my bad english,
i encountered a problem with turbulence suppression model, i have a profile with a chord of 1.84 m, a prism layer high 0.3 mm with 19 nodes (i can't realize a prism layer more high). compressible flow, freestream inlet, ideal gas, steady, tourbulent, SST kw model, CFL 1, two dimensional, i have 1 millions of cells i 2D. When i use gammaRetheta the solution converge but there is a fluctuation of the pressure coeficient in laminar zone while i use turbulence suppression the solution not converge (high fluctuation of residuals, drag and lift). I suppressed the turbulence in varius zone but the problem is the same: never converge. How i can resolve this problem? thanks Salvo |
November 30, 2016, 16:46 |
Andrea
Rep Power: 10 |
Maybe you should modify Courant number... Just a question, how did you suppress turbulence?
December 1, 2016, 21:16 |
#3 | |
Saima
Rep Power: 16 |
But i dont trust on my result as i am still getting reversed flow or re-circulation on outlet.
Best Redards, Saima |
December 2, 2016, 03:30 |
#4 | |
Andrea
Rep Power: 10 |
http://www.cfd-online.com/Forums/sho...d.php?t=180813 |
December 2, 2016, 05:49 |
Rep Power: 10 |
Andrrrew :
For turbulence suppression you should use the model they have implemented (Turbulence Suppression model). After you have to specify on which surfaces you suppress turbulence, it means probably splitting the surfaces of your body. |
December 2, 2016, 06:19 |
Andrea
Rep Power: 10 |
Hi taillanm, okok thanks, mainly my problem is on Tke residual...
http://www.cfd-online.com/Forums/sho...d.php?t=180813 Can you help me to stabilize it? |
December 2, 2016, 09:40 |
Rep Power: 10 |
Indeed the residuals indicate a problem linked probably to the mesh quality.. How does your mesh look like |
December 2, 2016, 12:10 |
Andrea
Rep Power: 10 |
It's about 1200000 cells with some refinements, as usual, for similar naval applications
turbulence suppression |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Turbulence length scale | Leonpolou | FLUENT | 2 | January 23, 2013 07:26 |
K - epsilon VS SST turbulence model | Maicol | Main CFD Forum | 0 | November 30, 2012 16:25 |
How to implement turbulence in one Solver??? | vahid.najafi | OpenFOAM Programming & Development | 0 | July 29, 2012 05:46 |
How's going on with Turbulence Research? | Daniel | Main CFD Forum | 1 | June 20, 2008 23:44 |
