Axisymmetric swirl
Old   July 9, 2014, 11:09
Default Axisymmetric swirl
etgau8 is on a distinguished road
I'm trying to simulate a vortex tube in starccm+ (http://en.wikipedia.org/wiki/Vortex_tube) . My first attempt is to perform a 2D axisymmetric simulation with swirl.
Models:
Axisymmetric
Axisymmetric Swirl
My boundary condition at the inlet is a Mass Flow Inlet. My problem is that I'm not able to find the place to set the swirl component at my inlet boundary condition. When I set the Flow direction, only the axial and radial component are used by starccm+ and the tangential component is ignored. Is there a specific setting that I didn't found where the ''swirl'' component at the inlet can be specified?
etgau8 is offline   Reply With Quote
Old   July 10, 2014, 02:58
kris
kguntur is on a distinguished road
Are you sure that the problem is axisymmetric? From what I understand, the flow will not be symmetric about the axis. You might have to simulate the 3D geometry.
kguntur is offline   Reply With Quote
Old   July 10, 2014, 09:45
Hi kguntur, thank you for your reply!
The problem can be considered as axisymmetric for a first approximation. The model axisymmetric with swirl has been used by several research group in the past (H.M Skye, R. Ricci, etc...). I'm trying to use this 2D model to study the impact of different boundary conditions and after that I will move to a a more complete 3D representation of the vortex tube.
My problem with this case is more related to the software. I am not able to find the way to apply a swirl velocity at the inlet with the model Axisymmetric Swirl.
Old   January 9, 2017, 06:03
Daniele Obiso
danobis is on a distinguished road
Hallo etgau8,
could you find a solution to your problem?
I am currently also trying to understand how to setup it for the 2D Axisymmetric Swirl Model.
Daniele
danobis is offline   Reply With Quote
Swirl component in inflow BC for 2d axisymmetric flows vishalsacharya OpenFOAM Pre-Processing 2 November 2, 2018 05:33
Axisymmetric swirl set up Pheasants FLUENT 0 January 14, 2014 06:11
Axisymmetric Swirl Arpit Tiwari Main CFD Forum 1 September 15, 2010 05:45
Axisymmetric swirl CHT with MRF Jonathan FLUENT 0 September 30, 2008 04:53
2d axisymmetric with swirl heather OpenFOAM Running, Solving & CFD 5 July 28, 2005 17:20
