Which solver required for humidity and temperature distributiion |
January 11, 2017, 15:47 |
Sandy
Rep Power: 9 |
Hello Star CCM+ user,
I have just stared using the star CCM+ and interested to find the humidity and temperature distribution in a house model.. can someone clear my following questions. Question regarding humidity calculations.. 1. Material used air, constant density(I am wondering where I can enter the properties for humidity) 2. which solver is required for calculating the humidity (passive solver? or any other) Question regarding the temperature distribution: 1. Which solver is required in order to calculate the temperature distribution in a building? Will appreciate any help! Sandy |
January 20, 2017, 01:33 |
Rep Power: 24 |
You want to use multi-component gas and have an air and a water vapor component. You probably don't want constant density if you intend on doing something in a room, especially where natural convection will dominate. You will most likely want the ideal gas equation of state.
I'm not sure what you mean by solver required for humidity and temperature, any of the solvers will do it. You just have to add the temperature model on to the physics. I would suggest you do a few tutorials before you hop in to doing your own work. |
January 25, 2017, 02:17 |
Armin
Rep Power: 9 |
This is the same problem that I have. I have used Ideal gas for it. It seems good from the first iteration. however, it won't converge and the humidity will increase up to maximum amount in everywhere. Please let me know your kind comment.
humidity, solver selection, temerature |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
OpenFOAM solver for incompressible BUT temperature dependent flow | niko0807 | OpenFOAM Running, Solving & CFD | 2 | October 27, 2015 05:31 |
Development of incompressible, temperature dependent solver | agustinvo | OpenFOAM Programming & Development | 16 | August 6, 2015 09:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
