Parallel Meshing
Old   January 26, 2017, 10:38
Default Parallel Meshing
acalado's Avatar
André
acalado is on a distinguished road
Hey guys.
I'd like to use the feature of parallel meshing to increase total RAM, however apparently only polyhedral model is available, and I would like to generate an extrusion.
Does anyone know if it is possible to mesh first the polyhedral region in parallel and then afterwards use a serial to create just the extruded cells?
Thanks in advance!
Sapere aude!
acalado is offline   Reply With Quote
Old   January 26, 2017, 11:18
acalado's Avatar
André
P.S.: When I use parallel meshing, in the beginning it uses all cores, but soon when it reaches 'Preparing surface for surface meshing' it reverts back to a single core. Is this normal??
Sapere aude!
Old   January 26, 2017, 11:43
acalado's Avatar
André
P.P.S.: Would parts based meshing be a solution?
Sapere aude!
Old   January 26, 2017, 16:29
Schwob77 is on a distinguished road
In 11.06 the extruder is available in Parts Based Meshing, so I would use that because you have the advantage to run the extruder separately from the initial volume mesh. So if you want a different number of layers you simply change it and execute the extruder operation without the need to re-create the whole volume mesh as well.
Surface meshing is only available in serial, so reverting back to serial for it is quite normal.
Schwob77 is offline   Reply With Quote
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 04:38
Parallel meshing using XP64 with PVM in CFX Mesh Huw ANSYS Meshing & Geometry 4 July 12, 2010 10:24
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
