forces on particles
Old   June 14, 2013, 19:32
Default forces on particles
Aashish Priye
netmaster is on a distinguished road
Hello all,
I was wondering if any one had a clue on how to approach a simulation model I am working on. I use Lagrangian particle tracking to introduce solid particles at the inlet of a pipe flow. The trajectories of the particles are calculated in accordance to the forces acting on it (namely just the drag force) due to the fluid flow (water). However, there are additional forces which acts on this particle such a force due to rotation of particle (called magnus force).
Is it possible to model of rotation/spinning of the particles as they travel with the flow. I anticipate that this would require the calculation of the torque on the particle surface due to fluid motion which would then give rise to the magnus force on the particle. Or is there any other way to implement it.
Any help on the topic will be highly appreciated and I thank you in advance for it.
Thanks
Aashish
netmaster is offline   Reply With Quote
Old   June 26, 2013, 09:47
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Yes, it is possible to model it. When you want to model the rotation, I assume that your particles are not spherical. when you are selecting the particle phase, it is enough to select non-spherical and Composite Particles Model. It is better to read more in tutorial about Composite Particles Model.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   June 29, 2013, 20:12
Aashish Priye
Thanks for the swift reply. I want to model rotation of particles (these can be spherical also). Currently I use Lagrangian particle tracking to calculate the particle trajectories in flow. The lagrangian particle tracking calculated the drag force on the particles (viscous drag due to the slip velocity between particle and fluid), pressure gradient force and the virtual mass force. However, I want the other forces such as the near wall Saffman force and force on the particle due to its rotation in the flow field.
Are you referring to the lagrangian particle model or something else. I was not able to find the any tutorial or reference of composite particles in the user manual. Thanks again.
Old   July 1, 2013, 04:16
siara817's Avatar
In your case, I do not think the Saffman force is important. Anyway, when you say you want to have a non-spherical particle in your simulation, then you need to make a particle with combination of spherical particles. from tutorial '' The DEM Particles model is represented in the Lagrangian phase by the DEM Particles node.DEM Lagrangian phases include phase models that allow you to define the shape of the particles as:Composite particles—Non-spherical particles with fixed bonds between the particle components.
Particle clumps—Non-spherical particles with breakable bonds between the particle components.
Spherical Particles—Single spherical particles.''
Good luck
Siamak
Old   October 15, 2014, 11:27
Default How to calculate the pressure gradient force
Jas
socreate is on a distinguished road
How to calculate the pressure gradient force of the particle? Fluent is used to solve the fluid flow. C_P_G may be not a good choice to calculate the pressure gradient force, which may cause instability. So, I don't know how to do. Could you give some suggestions?
Appreciate for your help!
Best regards,
socreate
socreate is offline   Reply With Quote
Old   March 16, 2016, 13:42
Mohammad Reza
Bana is on a distinguished road
Originally Posted by netmaster View Post
Hello all,
Thanks
Aashish
Hi
Have you found any solution to the problem of calculating slip-rotational lift or magnus force on particles? since openfoam doesn't compute the rotational motion of particles and the torque acting on them due to fluid motion.
thanks in advance
Bana is offline   Reply With Quote
Old   March 16, 2017, 04:27
Adam Katz
Adamkat is on a distinguished road
I am also interested in calculating the rotation and Magnus force.
Anyone have a solution?
Adamkat is offline   Reply With Quote
force, lagrangian, magnus, particle
Centripetal forces on particles in incompressible fluid sam1984_b OpenFOAM Running, Solving & CFD 4 December 14, 2018 06:16
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
Attractive forces and wall sticking for particles. nick978 FLUENT 1 April 7, 2011 08:52
forces acting on particles Lelia STAR-CCM+ 4 April 25, 2009 05:34
user forces on particles vadims CFX 0 March 22, 2007 09:49
