March 23, 2017, 12:29 |
Podded Propeller Simulation Problem
Nicholas Hughes
Rep Power: 9 |
I am modelling a fairly simple problem with a propeller, using sliding reference frame method. The physical testing boundaries are within a cavitation tunnel. I have completed the open water tests with good results. I am now attempting to partially block the flow (solid object covering part of the inlet- in an attempt to see the performance differences). I was able to model cavitation in the open water tests, however the divergence was almost immediate and getting floating point errors with the blocked flow. I have removed multiphase and VOF and I am now attempting to solve the problem without the cavitation. I am still getting floating point error before 10 iterations. Cell count ~2.1M time step is for 1 degree of rotation and max time is set to allow 3 rotations. models selected are: constant density, gradients, segregated flow, liquid, all y+, SST (menter), K-omega turbulence, RANS, exact wall distance, implicit unsteady, gravity, turbulent, 3D I have interfaces on the required boundaries however, they are very close to the blockage. I am unsure if this will affect their abilities or not. I hope I have provided enough information to provide an understanding of what I have and am trying to achieve. Thanks, Nick |
March 24, 2017, 01:13 |
#2 | |
Lane Carasik
Rep Power: 14 |
March 24, 2017, 03:39 |
Nicholas Hughes
Rep Power: 9 |
Hello Icarasik,
The boundary conditions are 'wall' for everything except the inlet (the large of two rectangles ahead of the propeller- flow is coming onto the propeller face), outlet at the opposite end and interfaces on all three surfaces of the rotating part. Nick |
March 25, 2017, 02:08 |
Rep Power: 24 |
Please post pictures of the mesh.
March 25, 2017, 07:07 |
Nicholas Hughes
Rep Power: 9 |
It's okay, I have worked my way through the problem and now have a perfectly running simulation. Thanks to anyone who got back to me! Nick |
March 31, 2017, 21:19 |
Chaotic Water
Rep Power: 17 |
Thank you not - for not sharing the solution.
Others might come across with similar question. |
blocked flow, interface, propeller |
Continuous casting simulation problem | luke.christ | FLUENT | 6 | November 24, 2020 07:14 |
Problem storing values at UDM for tranisient dynamic mesh simulation | xab | Fluent UDF and Scheme Programming | 4 | December 22, 2016 04:10 |
Problem in initializing transient simulation with a finer mesh | sidd | CFX | 8 | April 29, 2016 02:25 |
Dynamic mesh simulation (pimpleDyMFoam) problem | sidlof | OpenFOAM Running, Solving & CFD | 6 | April 12, 2013 11:24 |
simulation problem -- convection BC | pras | FLUENT | 4 | January 30, 2013 10:41 |
