very weird results 2d vs 3d simulation of airfoil |
April 11, 2017, 04:07 |
Dennis
Rep Power: 9 |
hello,
i have some weird results when simulating a multipart and multistory airfoil in 2D. In 2D i always get a stall in the wing in the second floor. But in 3D everything is right. I dont know what could be wrong here, i also have read the userbook. I used the polyhedralmesher and the realizable k-epsilon model. The firstpicture shows the 3D simulation with no stall. The second picture shows the 2D simulation where the wing in the second floor has differente angle of attacks and positions. Does somebody know what could be wrong? Does the turbulence modell assumptions things because its a simulation in 2D? |
April 11, 2017, 04:09 |
Dennis
Rep Power: 9 |
2D simulation picture
April 12, 2017, 21:13 |
Rep Power: 24 |
This isn't completely unexpected. Motion in the 3rd dimension (vortices) can help delay separation a lot. In 2d you are relying merely on momentum in 2 directions to keep things attached.
ke is not the best for this type of simulation, kw-SST is generally better at predicting separation here. Stall prediction is very hard to get right with RANS. Does it separate in the tunnel? |
April 13, 2017, 07:37 |
Dennis
Rep Power: 9 |
I have tried everything. Other turbulencemodels, refining the mesh, tried other meshes, change the boundary coniditions of the symmetrie wall to a normal wall with slip. But nothing works, the support from star ccm says it isnt a numerical error. But i dont understand it because in 3D it is a symmetrical wing, so the shouldnt be forces in the z-direction..
April 13, 2017, 10:52 |
Blanco
I would add that turbulence is definitely a 3D phenomena and you can't expect to correctly simulate vortexes in 2D, this comes from theory rather than software.
If you're using RANS then try k-w SST as suggested, keep y+ lower than 1 everywhere on the surfaces, try steady state and switch to transient if needed (check residuals + forces on the airfoils). Hope this could help, Regards |
April 14, 2017, 16:24 |
#6 | |
Dennis
Rep Power: 9 |
So i dont know what it could be.. |
April 13, 2017, 11:44 |
Rep Power: 24 |
April 16, 2017, 07:27 |
Dennis
Rep Power: 9 |
can i find this written somewhere in a book? because thats for my bachelor thesis. I didnt find something in the star ccm+ handbook..
April 16, 2017, 23:15 |
#9 | |
Rep Power: 24 |
A function f(x) has integral F=0. Because F=0, does this demand that f=0 everywhere? No, obviously, half of f could be -1 and the other half 1, or an infinite number of other possibilities. It would be a good idea to discuss this subject with your professor. |
2d simulation, 3d simulation, aerodynamics, airfoil, wing |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Oscillating Airfoil Poor Results at High k (reduced frequency) | dancfd | OpenFOAM Running, Solving & CFD | 3 | November 4, 2013 08:32 |
Airfoil Simulation for Validation Purposes | Angela Bong | Main CFD Forum | 7 | September 13, 2006 13:04 |
Compressible transonic airfoil RAE2822 simulation | Stefano | Siemens | 9 | June 21, 2006 10:47 |
