September 30, 2017, 11:07 |
Turbulence Length Scale approximation
#1 | |
Kacper
Rep Power: 8 |
Hi
I am simulating a flow over a 2D airfoil with 1m long chord in low turbulent intensity environment using k-omega (SST) model. From what I was able to find out online is that k-omega turbulence model is a 2 equation turbulence model for which k is the turbulence kinetic energy and omega is the specific turbulence dissipation rate. When calculating the kinetic energy I'm using the following equation: Quote:
Now when I want to calculate the Turbulent Dissipation Rate is there a rule of thumb or a similar rule/law which allows you to approximate the Turbulence Length Scale? From previous post on the forum the rule was that your length scale could be anything from 10 to 25% of your chord length. |
November 18, 2017, 23:46 |
For external flow, turbulence intensity (or level) is assumed to be below 1%. I always use 0.5% to be safe.
The way you have calculated turbulence kinetic energy is CORRECT. I use 10% of the chord length as length scale (assumption only). Thanks, LR |
what length scale should be used when calculating kolmogorov scale of fountain flow? | John-Lee | Main CFD Forum | 1 | May 9, 2017 02:16 |
DES Relative Length Scale in Fluent never positive, why? | ChezLeon | FLUENT | 1 | October 17, 2014 07:34 |
turbulence length scale? | Ms.Sheyda | Main CFD Forum | 3 | February 3, 2013 14:08 |
Turbulence intensity and length scale | eslam | CFX | 3 | January 14, 2008 16:37 |
Convergence vs. Length Scale | ahlo | CFX | 3 | November 1, 2007 17:20 |
