Turbulence Length Scale approximation
Like Tree1Likes
  • 1 Post By sabuj
Old   September 30, 2017, 11:07
Default Turbulence Length Scale approximation
Kacper
madakaczka is on a distinguished road
Hi
I am simulating a flow over a 2D airfoil with 1m long chord in low turbulent intensity environment using k-omega (SST) model.
From what I was able to find out online is that k-omega turbulence model is a 2 equation turbulence model for which k is the turbulence kinetic energy and omega is the specific turbulence dissipation rate. When calculating the kinetic energy I'm using the following equation:
where I cam assuming that the turbulent flow in the freestream is isotropic and that my turbulence intensity is 1%. Thus assuming that my freestream flow around the airfoil is at 12.5m/s. I get Turbulent Kinetic Energy of 0.0234375 J/kg. (Correct?)
Now when I want to calculate the Turbulent Dissipation Rate is there a rule of thumb or a similar rule/law which allows you to approximate the Turbulence Length Scale? From previous post on the forum the rule was that your length scale could be anything from 10 to 25% of your chord length.
madakaczka is offline   Reply With Quote
Old   November 18, 2017, 23:46
LR
sabuj is on a distinguished road
Send a message via Skype™ to sabuj
For external flow, turbulence intensity (or level) is assumed to be below 1%. I always use 0.5% to be safe.
The way you have calculated turbulence kinetic energy is CORRECT.
I use 10% of the chord length as length scale (assumption only).
Thanks,
LR
elmo555 likes this.
sabuj is offline   Reply With Quote
what length scale should be used when calculating kolmogorov scale of fountain flow? John-Lee Main CFD Forum 1 May 9, 2017 02:16
DES Relative Length Scale in Fluent never positive, why? ChezLeon FLUENT 1 October 17, 2014 07:34
turbulence length scale? Ms.Sheyda Main CFD Forum 3 February 3, 2013 14:08
Turbulence intensity and length scale eslam CFX 3 January 14, 2008 16:37
Convergence vs. Length Scale ahlo CFX 3 November 1, 2007 17:20
