Slip-Wall Behaviour
Like Tree1Likes
  • 1 Post By me3840
Old   November 21, 2017, 15:32
Default Slip-Wall Behaviour
InfernoxCJC's Avatar
Conor Crickmore
InfernoxCJC is on a distinguished road
Hey everyone,
As always, please forgive me if I am doing something stupid.
I am currently trying to replicate a wind tunnel experiment in STAR-CCM+ as a way of verifying that I can achieve some form of experimental correlation in my work.
With this in mind, I have established a model of the Wind Tunnel using the dimensions of the Working Section of the Tunnel in addition to extended slip-wall regions before the inlet and outlet in order to prevent inaccurate boundary layer. The method was recommended by my supervisor and is utilised in this paper.
The problem I am having is that I am experiencing what I believe to be strange behaviour along these slip-walls that is preventing any meaningful convergence. An example of this behaviour can be seen here, with 'odd' TKE behaviour prior to, and beyond, the working section, along these slip-walls. In addition to this, I am also seeing significant increase in free-stream velocity, above that of the inlet, throughout these regions.
I understand that this might not be sufficient information to fully explain the problem, and am happy to provide further details on request, but if anyone has any advice, I would be grateful.
Conor
InfernoxCJC is offline   Reply With Quote
Old   November 22, 2017, 01:48
me3840 is on a distinguished road
I don't think your slip wall is working. How did you specify it? Does it create a boundary layer like a normal wall?
InfernoxCJC likes this.
me3840 is offline   Reply With Quote
Old   November 22, 2017, 13:34
Conor Crickmore
It turns out it was to do with still having Prism Layers despite being a slip-wall. Rookie error on my part and a waste of compute time even if they hadn't caused an issue, but it seems the small size of the near wall cell was causing some form of disturbance at the inlet that was replicating the effects of a boundary layer.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 10:00
Slip flow boundary condition on wall using UDFs mahdi haddad FLUENT 1 November 11, 2014 06:13
Radiation interface hinca CFX 15 January 26, 2014 17:11
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
