How to do linear spring coupling in STAR CCM+? |
November 29, 2017, 10:41 |
sarva
Rep Power: 9 |
Hi All, I am trying to do simulate the Vortex Induced motion of Cylinder(3D case ) in the current case. So I tried to use a spring-mass system. But it is not working fine, i.e I didn't get a proper curve of translation pattern in cross-line direction and the spring disconnect from the cylinder after some iterations. So anyone suggests me about spring - structure coupling.
Thanks in advance. |
December 24, 2017, 16:16 |
Ping
Rep Power: 20 |
the key to getting springs to work properly is in the coordinate system settings for each end of the spring and it sounds like the inner ends in your example are not created under the moving body coordinate system so they do not follow the body's motion
linear spring, spring-mass system, vortex induced motion |
Star ccm and olga coupling | Mohtta | STAR-CCM+ | 0 | December 7, 2016 01:40 |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
