How to simulate a pile of static particles on the flow channel |
December 12, 2017, 16:50 |
Rep Power: 9 |
I came across a difficult problem. I'm trying to do this simulation using STAR-CCM+: a static pile of particles is rested on a flow channel and the fluid flow will flow across the pile of particle. I'm trying to simulate this process to study the particle movement. How to create the pile of particles on the flow channel that is initially static? |
December 13, 2017, 06:40 |
I don't know if it works for sure or not. But I can suggest one method. Create a DEM particles to make the pile. For this create a region where you need a pile of particles an then make it's wall non-penetrable for DEM particles. Calculate for how many particles do you want. Freeze flow solver and all except DEM. The n run (DEM only) for definite time based on you calculation for pile. Then unfreeze flow solver make wall penetrable and run the simulation. Hope this works, I am sorry if it doesn't .
December 13, 2017, 08:45 |
#3 | |
Rep Power: 9 |
Thank you so much for your reply! Your idea is valuable to me. Just a few more questions: 1. How to freeze all the solvers than DEM? 2. Whether the wall be penetrable or not is set in boundary conditions for DEM particles right? What if I use derived parts for injector? Thank you so much for your help! |
December 14, 2017, 01:16 |
#4 | |
December 14, 2017, 09:57 |
Rep Power: 9 |
Thank you so much for your help! Hope it work!
How to manage the pressure term in fixed mass flow rate based channel flow simulation | sjwon1991 | Main CFD Forum | 5 | July 10, 2017 07:21 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
Simulating a Laminar Isothermal Flow in a 2D rectangular Channel | HectorRedal | Main CFD Forum | 1 | December 18, 2016 11:41 |
Using k-omega SST to simulate simple channel flow | MaLa | OpenFOAM Running, Solving & CFD | 15 | June 19, 2014 04:48 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
