User-Defined Potential Force in multiphase flow |
January 11, 2018, 09:44 |
Rep Power: 8 |
Hello everyone. I have a question about the User-Defined Potential Force: Flow in a Porous Medium in the user guide.
the capillary pressure as user defined potential can be set according to Pc=-G0*C/Alpha ^m but C is related to Pc, which is C=Alpha /Gmma * dPc/d Alpha so how can I set the user define field function in this case? thanks!! Cen |
January 15, 2018, 15:11 |
Matt
Rep Power: 17 |
It would be helpful if you could specify exactly where you are seeing this in the user guide...
(i.e. user guide > modeling physics > etc...) That being said, you are missing some critical piece of information. if C is determined from the gradient of dPc/d alpha, then your system of equations isn't closed and you cannot solve for C. I will try to help you sort this out if you can provide a little more info. |
January 16, 2018, 03:08 |
#3 | |
Rep Power: 8 |
I saw this in: user guide > modeling physics > modeling multiphase flow > using the eulerian multiphase model > modeling user-defined potential forces > user-defined potential force: flow in a porous medium |
January 16, 2018, 13:41 |
Matt
Rep Power: 17 |
Ok... I have reviewed what is available in the help documentation. It does appear that you are referencing an old version of the files since I found this under:
Star CCM+ > Simulating Physics > Modeling Multiphase Flow > Using the Eulerian Multiphase Model > Modeling User-Defined Potential Forces That being said, I would check the most current help files on Steve Portal just in case there is something new that you don't see. Just glancing over what is shown, it looks to me like the user potential volume fraction derivative (dPc/d alpha) is a user input. Not being all that familiar with this particular model, I would speculate that your specific problem and materials will dictate what that derivative is. Good Luck. |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Multiphase flow in a pipe with a CHT | wissal | CFX | 4 | June 12, 2017 12:15 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
multiphase flow | leon_jar | CFX | 8 | November 4, 2015 02:06 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
