Very slow convergence for transient flow
Old   January 29, 2018, 09:43
Default Very slow convergence for transient flow
Akanksha Rawat
Akanksha90 is on a distinguished road
I am doing CHT simulations with transient solver for an electric motor. I have noticed that the heat transfer stability and temperature plots are progressing very slow even thought the time step is only 0.01 seconds.
Any tips to improve the solving time?
Thank you
Akanksha90 is offline   Reply With Quote
Old   January 29, 2018, 11:14
Matt
fluid23 is on a distinguished road
Try adjusting your relaxation factors on your solver(s).
fluid23 is offline   Reply With Quote
Old   January 30, 2018, 00:51
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Thank you
If I am correct for few thousand RPM time step of 0.01 s is not very small. In my simulations with gear box or pump I have used 1e-5 sec as my time step still one of my senior thinks that it is large. So the criteria for setting up your time step may be such that you have 1 degree revolution per time step. This may be the reason for slow convergence. But if you are not simulating the case with the revolution of the motor then your time step may be correct.
ashokac7 is offline   Reply With Quote
Old   February 7, 2018, 19:42
me3840 is on a distinguished road
Do you mean the temperature of the solids? Solids taking a long time to respond to temperature is pretty normal. Have you looked at the time constant for your solids? A hand calculation will get you pretty close to telling you how long it will take for them to stabilize.
me3840 is offline   Reply With Quote
Two Mass flow inlet bc convergence problem nabidinhomessi Main CFD Forum 5 December 14, 2015 07:11
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 06:32
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 04:44
3D Compressible Nozzle Flow Convergence Problem mep10jl FLUENT 2 July 30, 2013 17:09
momentum & x-vel convergence, and reverse flow problem cinwendy FLUENT 0 April 17, 2013 02:19
