February 24, 2018, 18:04 |
Hovering Rotor Simulation
luke sheehan
Rep Power: 8 |
Hi everyone,
I'm trying to run a hovering rotor simulation but I can't seem to make it match the Caradonna and Tung experimental data I want to compare against. The simulated coefficients of pressure are far above the experimental data particularly at X/C 0-0.4. I'm using a rigid body motion method so prescribing a rotation rate to the region containing the blades. Should I be using a multiphase model in my simulation? I've seen this mentioned in a few papers in order to capture the wake but I'm not sure if its necessary? Also if anyone knows any papers that take the RBM method and clearly spell out their methodology that would also be appreciated. Thanks |
helicopter rotor, rotor blade, star-ccm+ |
initial and boundary conditions for flapping hovering flight | quarkz | Main CFD Forum | 4 | August 30, 2012 13:11 |
Simulating a moving airfoil in hovering condition | quarkz | Main CFD Forum | 0 | November 12, 2010 18:44 |
Body forces on hovering airfoil | sanmysterio | Main CFD Forum | 1 | July 13, 2010 03:14 |
Efficiency for hovering flight? | Zonexo | Main CFD Forum | 1 | April 14, 2008 00:49 |
Hovering flight and Reynolds no. | Zonexo | Main CFD Forum | 1 | March 28, 2008 05:26 |
