Roughness function - small diameter tube
Old   April 21, 2009, 03:52
Default Roughness function - small diameter tube
Bernard Esterhuyse
bernarde is on a distinguished road
Hi all
Does anybody have any experience using the roughness function in Star-CCM+?
I have a simulation where I have flow through a tube with a very small diameter. I suspect that the relative surface roughness plays an important role. I have tried changing the "Wall surface specification" of the tube to "rough", and setting a roughness height, but I haven't seen any change in my results.
I'm making use of the k-omega turbulence model, and a low yplus grid to resolve the boundary layer completely. Does the roughness function only affect the wall function the turbulence model uses, and therefor have no effect if you are resolving the boundary layer?
I would ideally not like to explicitly add the roughness (ie draw it into the 3d model). Any suggestions are appreciated.
Thanks
bernarde is offline   Reply With Quote
Old   April 27, 2009, 11:34
Anton Lyaskin
A_Lyaskin is on a distinguished road
You are right - roughness function affects only the wall function for high Reynolds turbulence models
A_Lyaskin is offline   Reply With Quote
Old   April 28, 2009, 02:07
Bernard Esterhuyse
Thanks for the reply.
Do you have any idea how I can add roughness while using a low Reynolds number turbulence model?
Old   April 28, 2009, 04:11
Anton Lyaskin
For Lo-Reynolds you'll have to model it directly, sorry
I've seen a paper about accounting for roughness for two-layer models, but there are no two-layer models in STAR-CCM+, only in STAR-CD
It's just coming from the nature of different types of turbulence models - for Hi-Reynolds and for two-layer you're not solving the equations all the way down to the wall, you use some simple relations instead which you can modify to account for roughness. For Lo-Reynolds you're solving the equations in the whole near-wall region. Well, may be there is some way to modify damping terms, but I haven't seen any papers about it.
Old   April 28, 2009, 05:03
Bernard Esterhuyse
Thanks, I suspected that that might be the case. I will have a look at the difference between explicitly modeling it, using a low yplus grid, compared to making use of the roughness function with a high Reynolds number turbulence model. If I find something interesting I'll post it here.
Old   May 5, 2018, 06:54
Default Problem in using surface roughness function in Star CCM+
Shubhankar
Shubhankar94 is on a distinguished road
Hey! I am doing the same thing, flow through mini-channel, and I am also facing the same problem with the surface roughness. Please tell me how you solved it?
Shubhankar94 is offline   Reply With Quote
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
