How to choose an equation of state in physical model |
May 24, 2018, 10:48 |
Songkai Yang
Rep Power: 8 |
Hello everyone,
now i am working with cycle of the flow simulation in cylinder chamber but i do not know which EOS should i choose for a mixing of air and fuel, the result of desity according to T, P i have with matlab done. Thanks a lot |
May 24, 2018, 13:27 |
Matt
Rep Power: 17 |
You can use the user-defined EOS option when you define your physics continua. Then you just need to create a field function that has your EOS. Its a fairly easy process. The user manual has a good explanation. If a single equation is insufficient, you can always use the Table(T,P) function as well.
May 25, 2018, 15:37 |
#3 | |
Songkai Yang
Rep Power: 8 |
i get it and have a try |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Baldwin Lomax - Zero Equation Turbulence Model | shereez234 | OpenFOAM Programming & Development | 6 | June 21, 2016 02:13 |
