Sphere at Re=1e+7
Old   June 13, 2018, 07:24
Smile Sphere at Re=1e+7
Danny
danny9019 is on a distinguished road
i'm trying to simulate a 3D-Sphere in water at Reynolds Number 1e+7 (i.e. 10'000'000) in Star-CCM+, but at the moment i'm not achieving the correct CD result of about 0.19. My physics options are:
Velocity Inlet V = 10.014 m/s
Density rho= 998.6 kg/m3
Sphere Diameter D = 1m
Turbulence Model = K-w
Time = Steady
Fluid Type = Liquid.
The Mesh options on the body are:
Number of Prism Layer = 10
Stretching Factor = 1.5
Can someone please help me?
I really appreciate much.
-Danny-
danny9019 is offline   Reply With Quote
Old   June 13, 2018, 09:06
JOHN SHERJY SYRIAC
johnsherjy is on a distinguished road
hi..... The mesh near the sphere must be finely refined to capture the flow accurately..in order to that go to continnum..>mesh-->model-->click on prism layer mesher--->distribution mode-wall thickness(look at properties window)---> you can specify first layer thickness under reference value . First layer thickness can be calculated by online means with desired y+ value approx equal to 1
johnsherjy is offline   Reply With Quote
Old   June 13, 2018, 09:19
Danny
I'm running the analysis with these values:
Prism layer thickness = 2.5 cm
Number of prism layer = 40
Thickness of the near wall = 1e-6
And an y+ less than 1.
Could you tell me if this is a correct configuration?
Many thanks.
Old   June 13, 2018, 12:30
JOHN SHERJY SYRIAC
this seems right according to me
Old   June 14, 2018, 05:54
Danny
Hi, firstly many thanks. I've setted the grid in this way:
Number of prism layer = 22
Total prism layer lenght = 5 cm
Achieving an y+ maximum of 0.92 like in the attached picture.
Now my Cd is 0.12
What can i improve to rise the Cd value to the right 0.19?
Thanks so much.
Old   June 14, 2018, 11:30
Matt
fluid23 is on a distinguished road
what turbulence model and options are you using?
edit:
sorry, I see you are using k-w. still curious about your options.
make sure your wake is refined as well as your near wall mesh. the wake has an impact on drag.
also, try doing an unsteady simulation. your wake is definitely not steady and your cd will oscillate. the average of the oscillation is what you should report as your drag value.
fluid23 is offline   Reply With Quote
Old   June 15, 2018, 01:32
Default Hi
HHK
HHK's Avatar
HARIHARAN K
HHK is on a distinguished road
Hi
Based on my experience, cd is the challenging one compared to cl.
1.Are your reference values (density, area and velocity) okay with respect to the literature?
2.Try to use Spallart-Almarus turbulence model. It is meant for external flows.
3.(Most important) improve the prism layer meshing. Go for a stretch factor of 1.02 with y+<1.
Hope these suggestions help.
HHK is offline   Reply With Quote
Old   June 15, 2018, 06:16
Danny
i cannot reach y+ about 1...i don't know how to achieve that value..i tried all the ways. Can you help me please?
Old   June 15, 2018, 22:33
HHK
HHK's Avatar
HARIHARAN K
Try reducing the stretch factor with more number of prism layers. It should work.
Old   June 16, 2018, 09:25
Danny
ok i'm trying this way. hope works
drag coefficient, mesh 3d, starccm+
Possible to select Cells next to a SPHERE surface? keepfit OpenFOAM 2 November 30, 2016 15:47
[snappyHexMesh] Sphere in a channel by snappyHexMesh arsalan.dryi OpenFOAM Meshing & Mesh Conversion 0 November 14, 2016 16:01
defining sphere inside a cube model Wien3 OpenFOAM Running, Solving & CFD 6 November 26, 2014 03:37
[ICEM] meshing a sphere - large deviation from perfect sphere murx ANSYS Meshing & Geometry 25 August 15, 2012 12:37
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
