June 13, 2018, 07:24 |
Sphere at Re=1e+7
Danny
Rep Power: 7 |
i'm trying to simulate a 3D-Sphere in water at Reynolds Number 1e+7 (i.e. 10'000'000) in Star-CCM+, but at the moment i'm not achieving the correct CD result of about 0.19. My physics options are: Velocity Inlet V = 10.014 m/s Density rho= 998.6 kg/m3 Sphere Diameter D = 1m Turbulence Model = K-w Time = Steady Fluid Type = Liquid. The Mesh options on the body are: Number of Prism Layer = 10 Stretching Factor = 1.5 Can someone please help me? I really appreciate much. -Danny- |
June 13, 2018, 09:06 |
JOHN SHERJY SYRIAC
Rep Power: 8 |
hi..... The mesh near the sphere must be finely refined to capture the flow accurately..in order to that go to continnum..>mesh-->model-->click on prism layer mesher--->distribution mode-wall thickness(look at properties window)---> you can specify first layer thickness under reference value . First layer thickness can be calculated by online means with desired y+ value approx equal to 1
June 13, 2018, 09:19 |
Danny
Rep Power: 7 |
I'm running the analysis with these values:
Prism layer thickness = 2.5 cm Number of prism layer = 40 Thickness of the near wall = 1e-6 And an y+ less than 1. Could you tell me if this is a correct configuration? Many thanks. |
June 13, 2018, 12:30 |
JOHN SHERJY SYRIAC
Rep Power: 8 |
this seems right according to me
June 14, 2018, 05:54 |
Danny
Rep Power: 7 |
Hi, firstly many thanks. I've setted the grid in this way:
Number of prism layer = 22 Total prism layer lenght = 5 cm Achieving an y+ maximum of 0.92 like in the attached picture. Now my Cd is 0.12 What can i improve to rise the Cd value to the right 0.19? Thanks so much. |
June 14, 2018, 11:30 |
Matt
what turbulence model and options are you using?
edit: sorry, I see you are using k-w. still curious about your options. make sure your wake is refined as well as your near wall mesh. the wake has an impact on drag. also, try doing an unsteady simulation. your wake is definitely not steady and your cd will oscillate. the average of the oscillation is what you should report as your drag value. |
June 15, 2018, 01:32 |
Hi
HARIHARAN K
Rep Power: 11 |
Hi
Based on my experience, cd is the challenging one compared to cl. 1.Are your reference values (density, area and velocity) okay with respect to the literature? 2.Try to use Spallart-Almarus turbulence model. It is meant for external flows. 3.(Most important) improve the prism layer meshing. Go for a stretch factor of 1.02 with y+<1. Hope these suggestions help. |
June 15, 2018, 06:16 |
Danny
Rep Power: 7 |
i cannot reach y+ about 1...i don't know how to achieve that value..i tried all the ways. Can you help me please?
June 15, 2018, 22:33 |
HARIHARAN K
Rep Power: 11 |
Try reducing the stretch factor with more number of prism layers. It should work.
June 16, 2018, 09:25 |
Danny
Rep Power: 7 |
drag coefficient, mesh 3d, starccm+ |
Possible to select Cells next to a SPHERE surface? | keepfit | OpenFOAM | 2 | November 30, 2016 15:47 |
[snappyHexMesh] Sphere in a channel by snappyHexMesh | arsalan.dryi | OpenFOAM Meshing & Mesh Conversion | 0 | November 14, 2016 16:01 |
defining sphere inside a cube model | Wien3 | OpenFOAM Running, Solving & CFD | 6 | November 26, 2014 03:37 |
[ICEM] meshing a sphere - large deviation from perfect sphere | murx | ANSYS Meshing & Geometry | 25 | August 15, 2012 12:37 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
