How to simulate the ducted fan (12 blade and 7 stator) with one flow passage?
Old   June 14, 2023, 08:19
Default How to simulate the ducted fan (12 blade and 7 stator) with one flow passage?
Rinia
Rinia is on a distinguished road
Hello CFDers,
I'm performing a simulation about a 12 blade ducted fan (without stator) using the periodic boundary, i.e. only one blade is modelled. The whole domain is a 1/12 of the full fan. The sliding mesh is used to perform the transient simulation. The contact of rotating region and static region is set as repeating interface.
Now, I want to add the stator in the simulation, and the number of stator is 7, not consistent with the blade. How the domain is contructed in this case? Does the repeating interface still work here?
Sorry, I cannot upload the figure to show my simulation.
Rinia is offline   Reply With Quote
Old   June 15, 2023, 14:22
Lefteris
Aeronautics El. K. is on a distinguished road
But in your rotor blade, top and bottom are periodic boundaries, front and back are in and out. Same for the stator...
So, you need just one interface between them two?
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   June 15, 2023, 20:57
Rinia
Hello Lefteris,
The repeating interface work as periodic boundary and internal boundary in the STARCCM+, where the contact between two region is internal boundary and the un-contact area is periodic boundary.
The key problem is that the contact area between rotating and static regions is not equal since the 1/12 and 1/7 is set for the rotating and static region respectively. I can see that the flow in static region exceeding the contact area is not coherent.
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Fan with different blade passage width ArslanOZCAN CFX 5 December 20, 2016 20:47
[TurboGrid] Fan with different blade passage width ArslanOZCAN ANSYS Meshing & Geometry 0 December 12, 2016 04:05
Help need to simulate flow around Contra rotating Fan venkat_aero2007 Fidelity CFD 0 July 31, 2012 14:01
how to do this turbine blade passage flow nanlysis kaen CFX 0 January 17, 2006 22:50
