Pressure measurement by rotating probe on Helicopter blade |
August 16, 2018, 01:55 |
JOHN SHERJY SYRIAC
Rep Power: 7 |
I am simulating flow over a helicopter with 4 blades. I would like to find the pressure at the surface of one blade when it rotates 1 rev. I would like to create a rotating probe ie which moves with the blade motion. Could anyone please help me out how to make a rotate probe. Is there any option in the STARCCM+ software. Thanks in advance.
August 16, 2018, 02:55 |
#2 | |
Siddharth
Rep Power: 8 |
Did you try the point probes in Star CCM+? It has a "Follow motion" provision. Hope this helps. |
August 16, 2018, 04:38 |
JOHN SHERJY SYRIAC
Rep Power: 7 |
Thank you for the response. How can i plot the transcient pressure wrt time using this probe
August 16, 2018, 04:46 |
Siddharth
Rep Power: 8 |
August 16, 2018, 04:49 |
JOHN SHERJY SYRIAC
Rep Power: 7 |
Yes i hav tried to use that..yes i want to plot the pressure vs time graph
August 16, 2018, 04:51 |
JOHN SHERJY SYRIAC
Rep Power: 7 |
1)I also want to plot the same graph for number of points on the blade surface.Is there a way other than making a number of single probes.
2) Is there a way to fixed a point by selecting the surface without applying the coordinate of the point location |
August 16, 2018, 21:14 |
#7 | ||
Siddharth
Rep Power: 8 |
Also I am not sure which report to use so that you can get a pressure Vs time plot. Hope this helps. |
August 17, 2018, 05:29 |
JOHN SHERJY SYRIAC
Rep Power: 7 |
Hi
thank you for your response. Can you please tell how to snap the point to a part |
August 17, 2018, 07:48 |
Another suggestion!!
#9 |
Siddharth
Rep Power: 8 |
Hi
I checked it now. I think snap part and lock options are not enough for your case. Snap part constrains the motion of the point to the bounding box of the surface rather than the surface itself. I suggest the following which I got from this thread. 1. create a plane section at the required location selecting your surface as the part. 2. The result will be a line at the required location. 3. Now create another plane normal to previous plane selecting the previous plane as part 4. You should get a point at that location 5. Use this point for pressure measurement. I believe this point will follow the motion of your region automatically. Hope this helps. |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Convert DFT of pressure in rotating frame to stationary frame | CFD-123 | FLUENT | 0 | February 12, 2015 17:51 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
