Mesh problems
Like Tree3Likes
  • 1 Post By me3840
  • 1 Post By slesar85
  • 1 Post By Omel
Old   February 6, 2018, 08:05
Default Mesh problems
DesmoR is on a distinguished road
Hi guys.
I have some problem with my simulations of an open-wheel car.
I am doing a 3D steady analysis, but I get these errors:
-Conjugate-Gradient solver did not converge !
A floating point exception has occurred: floating point exception [Divide by zero]. The specific cause cannot be identified. Please refer to the troubleshooting section of the User's Guide.
Context: star.segregatedflow.SegregatedFlowSolver
-WARNING: Ap = 0 on multigrid level 6, nRows = 4203, blockSize = 1
AMG coarsening halted.
I don't understand where and what are the problems
Can you explain me why I get these two errors?
Thanks.
DesmoR is offline   Reply With Quote
Old   February 6, 2018, 08:09
Question
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Originally Posted by DesmoR View Post
Hi guys.
Thanks.
Check your set up first. You have to narrow down the possible problem. Like check your mesh quality and parameters. Check physics. Then try reducing urf of pressure velocity etc. What is your physics set up?
ashokac7 is offline   Reply With Quote
Old   February 6, 2018, 08:16
I am using K-omega SST with Segregated flow and second order convection. I left all the default values for the urf.
For example the problems appear if I just add a volumetric control for the wake.
Old   February 7, 2018, 00:42
ashokac7's Avatar
Ashok Chaudhari
ok so the problem may be with the mesh right!! May be there is sudden change in element sizes. Instead of using volumetric refinement we can use wake refinement. But it is available only with Automated mesh. You can refer CCM user guide.
Old   February 7, 2018, 19:49
me3840 is on a distinguished road
This error is a pretty common problem for wrapped cases, is it wrapped?
ashokac7 likes this.
me3840 is offline   Reply With Quote
Old   February 8, 2018, 04:25
No, it's not wrapped. I import the geometry files from rhino using .step or .iges format and then I use directly the subtract operation.
Old   February 8, 2018, 17:21
If you try to split the region by non-contiguous, does it result in more than one volume?
Old   February 9, 2018, 03:27
slesar85 is on a distinguished road
Yes, it's 100% solution. Each closed area must be a separate region
Romale likes this.
slesar85 is offline   Reply With Quote
Old   February 9, 2018, 04:37
I obtain only two more regions made of one cell each.
Should i get one more region for each part or just one?
Old   February 9, 2018, 04:42
Smile
ashokac7's Avatar
Ashok Chaudhari
There should be only one region. You should get message like no region would be created. If there are more then split them. You may decide if you want to keep them and then physics will be solved fro them otherwise delete them if they are unnecessary.
Old   February 9, 2018, 04:47
Ok thank you. I will try to delete them and run again the simulation.
I will let you know.
Old   November 6, 2018, 08:50
Omel is on a distinguished road
Worked for me. Thanks a lot
Omel is offline   Reply With Quote
Old   November 16, 2018, 09:56
Owen
SoAero is on a distinguished road
Are you saying that floating point errors are common when using the wrapper?
SoAero is offline   Reply With Quote
Old   November 16, 2018, 10:10
Not when used correctly. Floating point errors are very rarely the actual error in the simulation, they're usually a symptom of some other error, which includes user error.
The error I was referring to is the message from the AMG algorithm.
[Salome] Problems for creating mesh in salome to OPENFOAM bye bye my blue OpenFOAM Meshing & Mesh Conversion 8 December 5, 2023 00:57
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ANSYS Meshing] First layter thickness on mesh causing problems Rik102 ANSYS Meshing & Geometry 0 November 4, 2016 09:51
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
