velocity inlet profile
Old   October 3, 2018, 08:57
Post velocity inlet profile
Shekhar
shekharbhangale is on a distinguished road
Dear friends,
I've tried to create velocity inlet profile in my analysis. by below method,
1) Inlet type > velocity inlet
2) velocity specification > Magnitude + Direction
3) Flow direction specification > components
by this way an analysis was solved correctly. However, when I see the velocity magnitude is very less as it was in .csv table file(exported from previous analysis)
But the flow direction seems ok.
Can anyone please suggest, why the velocity magnitude is not considered in this analysis.
shekharbhangale is offline   Reply With Quote
Old   October 3, 2018, 09:37
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Originally Posted by shekharbhangale View Post
Dear friends,
Cross check your co-ordinate system for assigning the values and reporting the values. Both co-ordinate sys should be same. I prefer to create one by myself at inlet.
Hope this helps.
ashokac7 is offline   Reply With Quote
Old   October 26, 2018, 08:20
Shekhar
Thanks for suggesting. I will check the co-ordinate system.
Though I have not changed the co-ordinate system for both analysis. It was set to global.
I think As per your suggestion, I need to create local co-ordinate system while exporting velocity results. and same sys at Inlet (where the coupling is to be done)
combining parabolic inlet velocity profile with time varying velocity vector values jawapasu OpenFOAM 3 July 10, 2023 05:41
Velocity inlet BC profile antonio.c FLUENT 1 November 1, 2017 14:22
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 01:52
extracting outlet velocity profile from one case to another case's inlet tonggysun OpenFOAM 2 September 13, 2013 04:19
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 05:16
