October 19, 2017, 23:58 |
Input part for automated mesh (2D)
Reuben Buehler
I am constructing a 2D backward-facing step analysis. The part was created in 3D-CAD. I have created a "badge for 2D meshing" and the input part for this operation is the model domain. However, when I create the operation "automated mesh (2D)" and I go to select an input part the screen is blank and gives me no options to select. Any insight on what the problem might be?
P.S. The part has a surface that is orthogonal to the z-axis, the surface was created in the xy-plane and then extruded in the z-axis direction. |
October 20, 2017, 03:46 |
Marco Riedel
Rep Power: 15 |
Hi Reuben,
first you have to execute the "badge for 2D meshing" (right click on Geometry --> Operations --> Badge for 2D Meshing | Execute) and if everything works fine you can select your geometry. |
October 20, 2017, 13:51 |
Reuben Buehler
That worked perfectly. Thanks Marco!
November 2, 2018, 06:25 |
Hello, i have the same problem, but after Execute action nothing happens, selection menu is blank even so. What can go wrong?
November 2, 2018, 06:58 |
Marco Riedel
Rep Power: 15 |
I also had the problem and was confused that I haven't it one year ago. I could solve it by translating the geometry out of the z-plane , then execute "badge for 2D", translate the geometry back to the z-plane and execute "badge for 2D" again. Then it works for me.
[ICEM] Mirror Mesh | Delete duplicate mesh | pythag0ra5 | ANSYS Meshing & Geometry | 6 | November 19, 2013 07:35 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[ICEM] How to mesh part by part? | rikio | ANSYS Meshing & Geometry | 6 | February 24, 2010 19:19 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
