Change deprecated class in a macro
Old   November 22, 2018, 07:56
Default Change deprecated class in a macro
UchihaMadara is on a distinguished road
I am running the parseSTARCCMModel.java macro that comes with heeds, and uses the following in one of its line
else {
         DesignParameter designParameter = (DesignParameter) obj;
         scalarDesignParameterStream.append("\t" + designParameter.getPresentationName() + "=" + designParameter.getValue());
         scalarDesignParameterStream.append(" <class=" + designParameter.getClass().getSimpleName() + ">\n");
however the .getValue() is deprecated and it says the following in the starccm java api help page.
Deprecated. As of release 13.02. Use "getQuantity::getValue" method on the concrete class instead.
So, does anyone know what should be done in order to change the getValue() method?
Also a direction for how to refer the java api would be much helpful for future reference.
Kind thanks,
UchihaMadara is offline   Reply With Quote
Old   November 25, 2018, 20:05
me3840 is on a distinguished road
If you search the Steve portal there are articles on how to connect your IDE to the Java libraries that come with STAR. They will help you replace what you need.
me3840 is offline   Reply With Quote
deprecated api, java macro, macro java, starccm+, starccm+ macro
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 13:42
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
swirlinjector az1362f OpenFOAM Running, Solving & CFD 59 June 12, 2012 22:42
STAR-CCM+ Java class Claudene Siemens 1 July 17, 2008 05:49
