January 1, 2019, 21:35 |
about Maxium Inner Iterations
鲍健
Rep Power: 7 |
I am doing the tow-ways FSI problem on star-ccm,transient turbulence model ,using implicity coupling method.in field exchange control property dialog ,i set inner itraction every exchange 20,and I disabled Maxium Inner Iteractions ,then ,i found no curve appears in plot window and solution time always equal to 0s in scalar scene,but in residual the curves always change .
and when i active the Maxium Inner Iteractions,all plots window show the curve change. I do not know this problem . please help me |
January 2, 2019, 10:17 |
Rep Power: 24 |
If you disable the maximum inner iterations criterion then the solver will iterate on the same timestep endlessly provided there are no other stopping criterion active. That's why you see no solution time update.
I would suggest you either activate it or look at other stopping criterion. |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
