VOF sloshing
Old   October 26, 2013, 12:35
Default VOF sloshing
Kyle Beggs
kbeggs07 is on a distinguished road
Hello everybody, I am pretty new to star-ccm+ and know the basics, but i need some help to create a simulation of an oil pan (basically just a box with liquid in it to make it simple) under an acceleration to see the sloshing that happens. I have tried searching on here and throughout the internet and have found some stuff on this but it is brief. the real trouble is picking the models to use and setting up the oil/air mixture in the pan. i know i have the meshing and everything correct. Thanks for any help.
kbeggs07 is offline   Reply With Quote
Old   November 8, 2013, 01:48
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hii Kyle
I suggest you do the VOF head waves in a boat simulation. You'd understand the mechanics of using multiphase flow and volume of fluid.
In the tutorial you'll find how to give the wave motion inputs in the fluid.
ggulgulia is offline   Reply With Quote
Old   November 8, 2013, 02:04
Gajendra Gulgulia
Hey Kyle
I again went through your post. The models that you need to pick up are:
1. 3d
2. Implict Unsteady
3. Realizable k-e turbulence or k-omega turbulence model
4. Multiphase Flow
5. Volume of Fluid
Additional Models: Gravity
these are the compulsory models that you need to simulate the tank sloshing problem.
Old   November 11, 2013, 17:11
Kyle Beggs
Hello ggulgulia and thanks for replying. I have looked at the tutorials and completed the "VOF: gravity-driven flow" tutorial, it is most closely related to what i want to do, except i need 3-D. It also says to pick the same models as you said. now the problem is I cannot get the field functions to define the positions of the liquid and gas correct even though i do exactly as the tutorial. Is this because i have it in 3-D and not 2-D like the tutorial? Thanks so much for helping me.
Old   December 4, 2013, 07:04
Gajendra Gulgulia
Hey Kyle
If you know the fraction of both the fluids in the 3D geometry, then you would not need any field function for setting the initial condition. Just the the fraction of your liquid phase and gaseous phase need to be input in the field function.
If your 3d geometry is approximately symmetrical, then you can calculate the volume fraction using the height of one phase in a 2d geometry. In case you are still not able/comfortable with this approach, do let me know, i'll send you an example field function.
Old   December 6, 2013, 17:14
Kyle Beggs
I have it working now. Thanks a ton!!
Old   December 6, 2013, 23:54
Gajendra Gulgulia
all the best..keep in touch
Old   January 19, 2018, 01:14
Default sloshing in a container
vamsi
vamsiuchiha is on a distinguished road
hai...i am a beginner using starccm+...i am working on sloshing in a 2D container..can you help me out with creating a multiphase using userdefined functions and how to intialize the motion in the tank...i have been struggling a lot..
thanks
vamsiuchiha is offline   Reply With Quote
Old   January 2, 2020, 18:28
Default asking the tutorial
Aldias Bahatmaka
bmaldi is on a distinguished road
Hello man,
Could you share to me the tutorial of 2D sloshing to my email?
bahatmaka.aldias@gmail.com
I'll appreciate that.
thanks a lot.
Regards,
Aldi
bmaldi is offline   Reply With Quote
Sloshing using VOF at High Loads rsslnt FLUENT 1 November 29, 2012 12:13
VOF or not for sloshing of a full tank? Brian FLUENT 3 August 17, 2011 06:35
Using VOF for sloshing air-water boiling system Dibakar Rakshit FLUENT 0 March 12, 2008 07:40
VOF Sloshing - beating pattern in force output? Brian FLUENT 0 May 18, 2006 10:59
HELP.......sloshing problem using VOF suryakant FLUENT 3 August 11, 2005 13:32
