Determining Collection Efficiency When Using Lagrangian Multi-phase |
October 15, 2017, 20:58 |
Paul
Rep Power: 9 |
Hello all,
I am currently simulating water droplet impingement onto a wing. I am interested in determining the collection efficiency of the wing in order to compare with experimental data. My main question is: is there a direct way of determining collection efficiency that is built into STAR? If not, is there a way to write a field function that references values from the previous time step? I know there are a few ways of calculating collection efficiency. Specifically = ( * dh/dt)/(LWC * V_inf) -- where is the collection efficiency, is the film density, dh/dt is the increase in fluid film thickness over time, LWC is the liquid water content, and V_inf is the free stream velocity.If I am able to reference the previous time step values, I can just create a scene of a field function using (Film_Thickness_t-step2 - Film_Thickness_t-step1) = dh/dt. I would appreciate any input/suggestions you all may have. Thank you! |
March 12, 2019, 18:00 |
Ilia Art
Did you solve this problem? I have a similar problem for the steady flow simulation with Lagrangian Multiphase. Can not find any field functions that could satisfy the collection efficiency calculation. |
Multi Fluid Eulerian Model: defining secondary phase | weihong | Fluent Multiphase | 1 | July 18, 2017 12:24 |
required inputs in multi phase analysis | manishat88 | FLUENT | 0 | May 19, 2014 02:23 |
regarding multi phase flows | srikanth | Main CFD Forum | 1 | January 26, 2006 02:49 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Statistical Approach for Lagrangian Two Phase Model | Hesham El-Batsh | Main CFD Forum | 0 | November 20, 1998 09:20 |
