How to import data(xyz,time) to STAR-CCM+
Old   April 17, 2019, 13:59
Default How to import data(xyz,time) to STAR-CCM+
Mohamed
gaddora165 is on a distinguished road
Hi All,
I would like to import the volume fraction data for each time step to STAR-CCM+ simulation through the (xyz,time) option.
I'm having difficutly to fill-in correctly the excel file, becuase when i import my excel spreadsheet I won't be able to run the simulation.
can you help me to share your experience of importing excel file that intended to provide different values at different time step ?
appreciate if you can share with me the template of the excel spreadsheet to ensure that a specific volume fraction for each time-step.
highly looking forward to your respond.
gaddora165 is offline   Reply With Quote
Old   April 17, 2019, 22:24
Steve
steve lee is on a distinguished road
Use csv format and make like this..
x y z time
1 1 1 0
2 2 2 1
3 3 3 2
and than.. you should match each coordinate and time in CCM+.
x-coordinate -> x, y-coordinate->y, z-coordinate->z, time->t
try again good luck
steve lee is offline   Reply With Quote
Old   April 18, 2019, 07:48
Mohamed
Thanks for your respond.
I have tried doing what have you mentioned. but I found this error message:
VolumeFractionArrayProfile:: Component-0Profile: profile method properties not set correctly: Non-existent column "null"
what is the issue ?
even i have tried to change the time-step but still the simulation cannot run and showing me every time this message
I put 0 in all cells that is empty under all x, y, z columns.
appreciate your assistance.
Old   April 21, 2019, 21:38
Steve
Hi, Can you see your table contents after import?
You can check your report contents using right click on your table.
Also, you should check your sum of volume fraction is 1.
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
