Total pressure coefficient
Old   August 8, 2019, 12:48
Default Total pressure coefficient
Lauren
lauren_f1 is on a distinguished road
I have simulated a the flow around a car at 20m/s and the total pressure coefficient does not reach 1 in the freestream area. Usually you see mostly red in freestream so I think I must have a setting thats incorrect but I'm unsure what it could be. Instead of being 1 its around 0.4 or 0.5.
Any help would be greatly appreciated!
lauren_f1 is offline   Reply With Quote
Old   August 8, 2019, 23:04
me3840 is on a distinguished road
Did you set the total pressure coefficient reference parameters correctly?
me3840 is offline   Reply With Quote
Old   November 25, 2021, 08:20
spdesai is on a distinguished road
It could be several things:
1) You might be computing the total pressure coefficient incorrectly (check to make sure your reference static and dynamic pressures are correct).
2) Did you confirm that your computation is converged properly after conducting a grid refinement study?
3) Is your CFD input correct (for eg. the free stream velocity? Are you ensuring you're using the right solver etc.?)
spdesai is offline   Reply With Quote
cfd, cpt, pressure, simulation, star ccm+
Getting divergence while increasing the back pressure at pressure outlet greenfields15 FLUENT 0 March 18, 2018 23:39
Negative Total Pressure Loss Coefficient near the casing in axial compressor mitra22 CFX 1 December 15, 2017 22:34
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
Pressure Inlet: question about total pressure I-mech FLUENT 0 July 13, 2014 05:38
