September 24, 2019, 05:57 |
replace temperature
Österreich
Rep Power: 6 |
Hi guys,
only a short question, maybe someone can help me. I am using Vof and try to replace the temperature for Volume Fraction of Air = 1 every timestep. Is that possible and when yes how? Thanks. Michael |
September 24, 2019, 06:19 |
demirel suleyman
Rep Power: 9 |
Hello Mike,
Yes, is possible. I know two ways. You can specify the temperature as a field fuction of timestep or as a table with two columns, one temperature and the other time step and use the timestep interpolation method. I hope it helps. Mirel |
September 24, 2019, 06:40 |
Österreich
Rep Power: 6 |
Thank you for your reply. I already have a field function for the new temperature. There is already a field function defined for the temperature of the model. How can I set a new Temperature Field every timestep?
October 7, 2019, 08:35 |
demirel suleyman
Rep Power: 9 |
Hello Mike,
Sorry for the late answer but I was off the grid for the past weeks. Did you solved your issue? If not I can try to help you on this topic. Mirel |
October 8, 2019, 03:31 |
Ping
Rep Power: 20 |
if you want to change the temperature on a boundary then apply your temperature field function at the boundary
if you want to change the temperature within all the air then you do this using a volume source and there is a great steve support article to advise on this concept but I cant remember the article other than if you search for 'monkey' you will find it since the found article shows how to set local momentum values using sources |
October 9, 2019, 11:24 |
Österreich
Rep Power: 6 |
Hi guys,
thanks for your reply. I think I have found a solution. But I have a second question. Is it possible in CCM+ to use a mass source in a vof based model? thanks |
October 9, 2019, 22:55 |
Ping
Rep Power: 20 |
yes - clearly explained in the user guide
October 10, 2019, 04:04 |
Österreich
Rep Power: 6 |
Thats true, but i can not find it in the model tree. In the user guide it is written, that in every flow region mass source can be activated
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
difference of temperature | HKH | FLUENT | 0 | January 28, 2010 02:45 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
