January 10, 2020, 13:10 |
Meshing with STARCCM+
Julien
Rep Power: 6 |
I'm trying to mesh a rectangular domain (3D) with STAR CCM+. It represents a volume of air with an inlet, a ground, a sky (and a building inside). I would like to create a boundary layer over the ground to catch velocity gradients near the ground ( I put a field function for the inlet profile), however my boundary layer seems to apply on all edges while i only want the ground to be done. How could I proceed ? ( and what type of region should I assign to the sky and sides of the domain which are juste a simple exit for the air ? ) |
January 10, 2020, 18:31 |
Chaotic Water
Rep Power: 17 |
Either with a Surface Control (in Parts Mesher) with Prism Layer set to disabled.
Or - what looks like real source of problem: by default meshers build prism layers at walls and do not do that at openings (inlets, outlets) and symmetry; so - assign boundary condition types first, then - mesh. |
layer addition, mesh 3d, star ccm+ |
Meshing Process | sidharth9426 | STAR-CCM+ | 4 | September 15, 2015 03:31 |
[ANSYS Meshing] Meshing strategy for External Flows | Hybrid | ANSYS Meshing & Geometry | 0 | January 24, 2012 14:27 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Meshing Errors in Starccm | Josh Kempenaar | Siemens | 2 | November 30, 2006 08:14 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
