November 14, 2019, 14:55 |
Problems with input parameters
Ярослав
Hello, I'm new to Star CCM+. Please help me. Imagine a pipe and water flows in it. I only know the value of the differential pressure, such as inlet pressure(P1) and outlet pressure (P2). Given: P1-P2=15 atmospheres (atm). How do I do that? I think it is necessary to create a field function, but how?
P.S. forgive me for my English. I don't speak it well. |
November 14, 2019, 21:53 |
#2 | |
Chaotic Water
Inlet: Stagnation Inlet with Pressure set to 15 atm
Outlet: Pressure Outlet with Pressure set to 0 atm All those pressure values are given with respect to Reference Pressure (in Continua -> Physics -> Reference Values -> Reference Pressure) which is 1 atm by default, so absolute pressure would be 16 atm and 1 atm. No difference for incompressible flow, but keep that in mind for compressible flows. But if you just set 15 atm at Inlet - you'll get high velocity in first iterations, so it is better to increase the pressure at inlet as iterations go, for example via a Field Function: Quote:
PS Если с английским тяжко - найди группу по стар вконтакте. |
inlet and outlet pressure, star ccm+ |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
Getting different values for defined input parameters in fluent | Sagar7 | FLUENT | 0 | August 29, 2017 13:04 |
A UDF for mixture outlet variable derived from two other input parameters? | ebtedaei | FLUENT | 0 | July 12, 2017 02:17 |
How to get Pro/E Parameters to Show Up | Trues | CFX | 4 | September 17, 2012 20:26 |
Parameters for multigrid solver | HaZe | OpenFOAM Running, Solving & CFD | 3 | January 28, 2012 02:05 |
