March 6, 2020, 03:12 |
Floating Point Exception for k-w SST
Rep Power: 12 |
I am working on atmospheric boundary layer simulations and flow through an urban environment. I have been using realizable k-e with much success, utilizing boundary conditions and initial values etc. from best practice guidelines. However, whilst I can also obtain good results with standard k-e, when I make the switch to k-w SST (and k-w standard), I get a floating point exception (divide by zero) before the first iteration.
I believe I've correctly converted turbulence dissipation rate to specific dissipation rate for boundary/initial conditions. Is there a theoretical reason for this disparity in performance? What would a possible solution look like? EDIT: I should add that this only occurs when using the all y+ wall treatment. When I switch to the high y+ wall treatment, the simulation runs as expected but underestimates the magnitude of turbulent kinetic energy throughout the environment. Last edited by Muzz; March 6, 2020 at 16:03. |
March 9, 2020, 12:17 |
#2 | |
Lucky
Rep Power: 66 |
If you are using the same approach for the boundary conditions (intensity and length scale, or whatever) then it's likely your initial condition.
You might want to try using field functions to convert the epsilon field into omega values when you switch models. If you are starting with a new case where you don't have a nice epsilon field, then you come up with better initial guesses. |
March 9, 2020, 14:33 |
#3 | |
Rep Power: 12 |
What I don't get is how I can have good convergence with SKE and RKE but not have it work at all for KW-SST. What do you think the link is between the failure of the simulation and the wall treatment model? It works for High y+ but not All y+. I am using All y+ for SKE and RKE sims with no issue. Thanks again for your contribution. |
March 9, 2020, 15:23 |
Rep Power: 12 |
After looking for answers on the steve portal, it recommends using -fpe in the command line when loading the .sim file, to generate more meaningful errors. The result is this:
SIGFPE: floating point exception Command: Automation.Run Recoverability: Non-recoverable ServerStack: [SymInit: Symbol-SearchPath: '.', symOptions: 530, UserName: 'Desktop' , OS-Version: 6.2.9200 () 0x300-0x1 , 00007FFEE2538BD4 (KwTurbModel): (filename not available): KwTurbLowReUstarEquation::KwTurbLowReUstarEquation , 00007FFEE2519049 (KwTurbModel): (filename not available): KwAllYplusWallTreatment::setProperties , 00007FFEE25179B1 (KwTurbModel): (filename not available): KwAllYplusWallTreatment::setProperties , 00007FFEE250F102 (KwTurbModel): (filename not available): KwWallTreatmentModel::getWallTreatmentDomain , 00007FFEFB3D9A26 (StarSolve): (filename not available): VerifiedFaceTerm::VerifiedFaceTerm , 00007FFEFB3DB1FA (StarSolve): (filename not available): VerifiedFaceTerm::verifiedEvaluate , 00007FFEFB3DEF3D (StarSolve): (filename not available): SelectiveFaceTerm::evaluate , 00007FFEE2515E92 (KwTurbModel): (filename not available): KwAllYplusWallTreatment::accumulateTkeEquationWall Sources , 00007FFEE272952B (KwTurbModel): (filename not available): KwTurbTkeBoundaryConditions::eval , 00007FFEE2613349 (KwTurbModel): (filename not available): KwTurbModel::accumulateSources , 00007FFEE2795442 (KwTurbModel): (filename not available): MenterKwTurbModel::accumulateSources , 00007FFEE2718FC7 (KwTurbModel): (filename not available): KwTurbSlipVelocitySolver::getClassVersion , 00007FFEE27186C5 (KwTurbModel): (filename not available): KwTurbSlipVelocitySolver::getClassVersion , 00007FFEFB5385AB (StarSolve): (filename not available): RunnableSolver::doSolverIterationUpdate , 00007FFEFB5371E1 (StarSolve): (filename not available): RunnableSolver::iterate , 00007FFEFB54521F (StarSolve): (filename not available): SimulationIterator::startSimulation , 00007FFEFB566413 (StarSolve): (filename not available): SimulationIterator::stopSimulation , 00007FFF1867CA7F (StarNeo): (filename not available): Controller::executeCommand , 00007FFF1867BB2C (StarNeo): (filename not available): Controller:: processCommands , 00007FFF1A484779 (StarMachine): (filename not available): CommandController::scatterCommand , 00007FFF1A483453 (StarMachine): (filename not available): CommandController:: processCommands , 00007FFF1A5535EA (StarMachine): (filename not available): Machine::startServerHost , 00007FFF1A53F618 (StarMachine): (filename not available): Machine::main , ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF6B4501EE0) , 00007FF6B4501EE0 (star-ccm+): (filename not available): (function-name not available) , ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00007FF6B450FEAF) , 00007FF6B450FEAF (star-ccm+): (filename not available): (function-name not available) , 00007FFF6D777BD4 (KERNEL32): (filename not available): BaseThreadInitThunk , 00007FFF6DACCED1 (ntdll): (filename not available): RtlUserThreadStart Does this mean anything? |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 09:08 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 04:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 13:56 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 19:28 |
