Using cylindrical coordinates
Like Tree2Likes
  • 2 Post By kirrer
Old   June 29, 2016, 06:09
Question Using cylindrical coordinates
harry123 is on a distinguished road
Can someone tell me how to use cylindrical coordinate (radius) value in defining a field functin ?
I have made this Cylindrical coordinate system under Tools>coordinate system>Laboratory>Local coordinate system.
I would like to use the radial length in a field function. The function ${RadialCoordinate} seems to give me axial length. (My radial length is in the original X axis direction and axis lies along Y axis)
Thanks for your replies and suggestions.
harry123 is offline   Reply With Quote
Old   June 29, 2016, 16:01
Kevin
kirrer is on a distinguished road
You can refer to components of a coordinate system (or any vector component) using the [i] notation, with i=0 for the first element, i=1 for the 2nd, etc. In a field function, $$Position[0] returns the x-coordinate in the lab coordinate system. For a custom coordinate system, you need to add the name in parenthesis and quotes like $$Position("myCustomCsys")[0]. For positions, 0 refers to x, 1 refers to y, 2 refers to z component of the position vector. In the case of a cylindrical coordinate system, 0 refers to radius, 1 refers to theta, and 2 refers to z. More info (including embedded coordinate systems) is in the user guide, search for "Referencing Field Functions, Coordinate Systems, and Reference Frames".
I should add, I believe that $RadialCoordinate refers to the coordinate with respect to the region's defined axis. Under the Region you can define the axis origin and orientation for this and other purposes (like moving reference frame). So, typically you are better off defining the coordinate system and referring to components as indicated above, rather than defining the region axis and using RadialCoordinate (or TangentialVelocity, etc).
marmot and harry123 like this.
kirrer is offline   Reply With Quote
Old   July 1, 2016, 03:26
Thank you very much. That helped a lot.
Old   May 25, 2020, 12:20
Daniel
DanielStar is on a distinguished road
I still dont get it, lets say I want to make a drag force report on a rotating body, hence I need to choose theta direction. How do I write it?
Assuming that Cylindrical 1 is my cylindrical coordinate system, is that will be okay?
$$Position("Cylindrical 1")[0,1,0]
or I should write:
[$$Position("Cylindrical 1")[0]=0 ,$$Position("Cylindrical 1")[1]=1 , $$Position("Cylindrical 1")[2]=0]
I don't see my coordinate system on the options list, there is a screenshot:
https://ibb.co/wg4w0pS
DanielStar is offline   Reply With Quote
Finite Volume Method For Cylindrical Coordinates falopsy Main CFD Forum 45 August 14, 2023 21:14
working in cylindrical coordinates in fluent Randheer Yadav FLUENT 2 January 18, 2015 16:25
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
Cylindrical coordinates ? T.D. OpenFOAM Running, Solving & CFD 17 September 26, 2010 15:37
Calculation in cylindrical coordinates Franz Wingelhofer CFX 0 December 28, 1999 07:46
