Surface extruder boundaries
Old   June 28, 2020, 17:32
Default Surface extruder boundaries
The
Blegh
The is on a distinguished road
Hello, I'm new to cfd so please go light on me
I want to extrude my mesh (automated polygonal) on the outlet surface (pressure outlet). So far so good, I set up the surface extruder, then the volume extruder with the surface extruder as input part and assigned the new surfaces as regions. Now: the surface extruder automatically creates an interface but now I have two boundaries on the same place (outlet). When I try to simulate its only getting calculated for the old mesh, not the extended. What type of interface do I have to choose? What boundary condition do I have to use for my interface regions? All I want to do is to relocate my outlet surface 0.5m backwards.
The is offline   Reply With Quote
Old   July 6, 2020, 21:58
Ping
ping is on a distinguished road
it is not that clear what has gone wrong but maybe you did not assign the new part created but the extrusion to a region - read the help at Pre-Processing > Meshing > The Meshing Workflow > Extruding Surfaces from a Parts-Based Volume Mesh.
if it is simply an interface issue then you need an inplace interface to allow flow thru and the outlet might need setting too. also check you have volume mesh in the extruded volume.
ping is offline   Reply With Quote
Old   July 8, 2020, 07:17
Kushal Puri
Kushal Puri is on a distinguished road
Just change that old outlet boundary to wall it will automatically make interface.
Kushal Puri is offline   Reply With Quote
Old   July 8, 2020, 11:27
The
Blegh
Hello, thanks a lot for the replies. I used the false interface definition. Dumb mistake
extrudemesh, mesh 3d, star-ccm+
SnappyHexMesh... Domain boundaries are uneven Blue8655 OpenFOAM Pre-Processing 0 January 20, 2016 11:43
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
