July 16, 2020, 11:55 |
Bulk temperature of periodic flow
Hello.
I 'm currently trying to calculate a circular tube model with a fully developed flow, but I'm faced by a probldm. The procedure to specify the region condition is as follows: 1. Apply a constant temperature to the side wall. 2. Define velocity inlet on the inflow surface and pressure outlet on the outflow surface. 3. Create a periodic interface (type: fully developed interface) on these two faces. 4. Drive the flow with a pressure gradient. I would like to perform a calculation where the hot mainstream is isothermally cooled by the walls, but I can't find a way to specify the bulk temperature for the inflow surface. What should I do? Computational model: 3D/Gas/K-Omega turbulence/implicit unsteady flow/constant density/segregated flow/segregated fluid temperature |
boudary condition, bulk temperature, fully developed interface |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
periodic straight tube flow, no mesh independent solution for pressure gradient | thijs1909 | FLUENT | 5 | May 16, 2018 09:04 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Periodic channel flow with time dependent mass flow rate | QBeast | FLUENT | 3 | May 10, 2013 13:14 |
calculation of bulk temperature in channel flow | moshe | FLUENT | 0 | May 13, 2007 09:57 |
